O2 Sensor
Old Jul 31, 2007 | 12:27 PM
optic462's Avatar
optic462
O2 Sensor
I have a 2005 Ranger Edge. I live in Virginia which requires your vehicle to pass state emissions tests. My truck failed I was told that my O2 sensor went bad. However, there are 2 sensors for each cylinder head. I am assuming that means 1 upstream and 1 downstream for each head right? They told me that it was my O2 sensor in the #2 bank; is that left? Also, how do you know if its the upstream or downstream sensor. Does anyone have any insight to this, or prior experience? The actual OBD code was P2272.
Old Jul 31, 2007 | 12:53 PM
87 XLT's Avatar
87 XLT
Looked at my list of OBD-2 codes & dont find a P2272. Are you sure thats correct?
Old Jul 31, 2007 | 01:08 PM
wtroger's Avatar
wtroger
Bank 2 sensor 2 It would be the down stream one I believe it is on the drivers side but since I do not have my manuals in front of me do not take that as gospel. check a haynes or motors manual for bank designation I am not well versed in the 3.0 engines.
Old Jul 31, 2007 | 02:14 PM
optic462's Avatar
optic462
Thanks for your halp WTROGER, it was the downstream sensor. Which works out for me because the downstream sensor is about $12 cheaper and a LOT easier to get to.
2011KingR
Oct 18, 2016 12:10 PM
celsoglima
May 5, 2015 12:16 PM
iamvandemon
1997 - 2003 F150
Mar 17, 2015 05:25 PM
mfp4073
Nov 26, 2014 11:47 AM
F-WhiteThunder
Sep 17, 2014 07:19 AM
