New battery recommendations
Old Feb 19, 2023 | 01:36 PM
Big-Dawg's Avatar
Big-Dawg
Hello all,
With the rising cost and shorter life expectancy, I’m in need of a new battery and need advice on which battery has done the best for you and why. I’m currently using a group 56 on my 86’ XLT Lariat with a 302, with AOD. What other sizes will fit? Not looking to do the high end AGM style. Thanks for the help with this.
Old Feb 19, 2023 | 03:54 PM
BigBlue2's Avatar
BigBlue2
I checked interstate batteries for your truck and only one came up. It was a group 56.
Seems many battery mfgrs have battery look ups. Try your favorite brand's battery look up.
I've had excellent results with interstate batteries. Others have had issues. Go with what you know. Get one that fits your hold down set up. If you have the original hold down that will limit your width. Your battery pan would limit the length.
If I were you I'd look for another group 56.
Old Feb 19, 2023 | 04:05 PM
kr98664's Avatar
kr98664
Where's my 11-foot pole? You may as well have asked which oil is best? Maybe we should discuss politics?
I've been very happy with the top of the line offerings from a certain auto parts chain named after a famous wine-producing valley in California. I use them in all my vehicles.
Whatever brand and size you get, be aware most stores offer various price points. They'll typically have a low quality version to compete on price against discounters. They'll also have higher end stuff with the best quality, and stuff in between. In my over-inflated opinion, you do get what you pay for, so don't go cheap.
Old Feb 19, 2023 | 05:25 PM
hobohilton's Avatar
hobohilton
Shows you in NC so you are not in an "extreme" temperature environment. If you are using your truck for just "normal" chores then consider replacing the battery with something as close to an OEM battery as possible.
Same weight, plates and warranty. Should put you about mid-range on price, also.
JMHO
Old Feb 19, 2023 | 06:27 PM
Franklin2's Avatar
Franklin2
I have started buying "used" batteries and they have been working well. If you have a interstate battery store, they should have them. Some Autozone stores have them. Advance auto has them. They are brand new batteries that have set on the shelf too long for them to sell them as new. They usually give you a 30 day warranty.
Just take your tape measure and measure your battery. You will find a lot of batteries are mostly the same size. And then take note of the + and - locations. If your battery cables have some extra length, most of the time you and turn the battery around if the + and - are swapped and get it to work.
Old Feb 20, 2023 | 07:02 AM
FuzzFace2's Avatar
FuzzFace2
When I lived in CT I used Interstate batteries as they did me pretty good over the years but down here in NC I dont know where to get them and most of the time I need it now so I hit the local parts store.
As for "Shows you in NC so you are not in an "extreme" temperature environment." we may not have really cold temps, but during the summer it dose get pretty hot, close to 100*f a lot, and add under hood heat and that will kill a battery just as fast as cold.
Down here (NC) I dont worry to much about the CCA because it does not get that cold but I also dont have anything that has to crank a lot like a diesel, before it fires up.
Dave ----
Old Feb 20, 2023 | 11:08 AM
BigBlue2's Avatar
BigBlue2
Napa Valley is famous for wine grapes but National Automotive Parts Association (NAPA), is a great place for finding good parts.
I'm pretty sure I read in the FTE guidelines that politics is off the table unless it directly relates to Ford Trucks, like emissions, titles, registrations and other areas where polyticks overlaps...
Old Feb 20, 2023 | 02:37 PM
diggerrigger's Avatar
diggerrigger
In 1986 the heavy duty battery offering in new trucks was the 64, about thirteen inches long. My truck came with one. Right now I'm running a 52. It is slightly larger than a lawn tractor battery
Custom hold down.
One thing to keep in mind when asking for a battery for these trucks is that they will look it up and find the 56 as the battery recommended. It's not that common a size. Chances are, not stocked.
Old Feb 20, 2023 | 05:36 PM
Franklin2's Avatar
Franklin2
My local Walmart keeps a group 51R in stock. You can see below it's slightly smaller but the terminals should be the same.
https://batterygroupexpert.com/group-56-battery/
Old Feb 21, 2023 | 04:26 AM
Comfortmichael4's Avatar
Comfortmichael4
I run a group 65. Of course I went to the part store and they told me I needed a group 56 but it just doesn't seem to fit in the battery hold down as well as the 65 does. And to boot I've previously used a 56 and it just didn't have the power properly start [my truck] emphasis on My truck. I don't know about other people's trucks but my 86 f150 ran through 2 starters and a starter solenoid during the year and half period of time I used a group 56. Second time the starter went out my mechanic mentioned my battery looked too small so I got a bigger battery and haven't had a problem since.
but as always take my words with a grain of salt as I am a young man and your truck might not have the same ticks mine does
Old Feb 21, 2023 | 06:05 AM
Jonnyuma's Avatar
Jonnyuma
Buy a Walmart battery with the replacement warranty. When itcraps the bed before the warranty has expired (it will) you get a new battery every year or two.
If l ever get an Everstart battery to outlive it's warranty, I'll be buying a different battery. The two that l have left, like ALL Everstart batteries, were in vehicles when l bought them.
jyarosz
2015 - 2020 F150
17
Nov 24, 2021 02:29 PM
BBsound
2021+ F150
Oct 27, 2021 05:32 PM
Oceanwinds
2015 - 2020 F150
13
Jan 26, 2020 07:30 PM
D Harry
Mar 6, 2017 09:31 AM
Joeblowv1
Feb 5, 2016 11:19 AM
