Ebpv delete, need help
Old Feb 19, 2023 | 01:24 AM
rangeron33s's Avatar
rangeron33s
4wd High
I just installed the kc300x turbo on my 7.3 and i want to know some things before i order the bypass plug for the ebpv plug. Am i able to just cut the wires and do the old school bypass? Or does the bypass plug have some kind of resistor in it? I cant find a write up on how it works.
Old Feb 19, 2023 | 07:24 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
For a few years I used a 470 ohm 1/2 watt resistor (ebay) between the two contacts of the OEM plug. I eventually removed that and installed a code eliminator from RiffRaff. There are/were cheaper code eliminator available, but like supporting small businesses that are reputable and I was ordering some other parts anyway.
I hope this helps.
Elanham59
Feb 18, 2022 08:37 AM
cougmyster
Oct 26, 2021 07:22 AM
MillennialAntiTheftDevice
24
Apr 9, 2021 11:43 PM
ve7kilohertz
Jun 20, 2012 10:19 PM
99F-250lova
Jan 23, 2006 08:35 AM
