Help! No start (not typical issue)
Old Feb 17, 2023 | 04:59 PM
Junktownbill99's Avatar
Junktownbill99
When I try and crank my starter, it makes this rough kind of slow clicking noise, like it isn't quite catching the flywheel, it isn't very fast, but I don't know what to do, (it was working earlier today)
Edit: it sounds kinda like a machine gun, but won't actually crank
Old Feb 17, 2023 | 06:29 PM
Olds64's Avatar
Olds64
Do the batteries have a good charge? If you don't have a charger most auto parts stores will charge them if you bring them in.
Old Feb 17, 2023 | 06:38 PM
Junktownbill99
I will definitely try that, I don't think I left anything on, like glow plugs, key, etc, but it's always a possibility. (I do have a charger luckily)
Old Feb 17, 2023 | 09:04 PM
Prototypemech's Avatar
Prototypemech
How many times per second is it clicking? If it's about 10 times a second (or faster than you can count), it's probably your starter solenoid clicking because you have low batteries.
Old Feb 17, 2023 | 11:29 PM
Junktownbill99
It is about that fast, it sounds like the starter is not quite hitting the flywheel l, and it may be the batteries cause blower sounds weak, I think I left the glow plugs on and it drained it
Old Feb 18, 2023 | 08:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
could be bad batteries, or bad positive OR negative cables, or simply a bad cable connection at battery or or other end of cables. .
Old Feb 19, 2023 | 04:16 PM
Junktownbill99
Good news! My batteries were just dead (phew) any idea where a fuse would be for the glow plugs? Mine don't turn on (1984 6.9)
Old Feb 19, 2023 | 05:12 PM
tjc transport
i ain't rite
no fuse. there should be a fusible link coming off the starter relay on the fender going to the controller on top rail of the back of the block.
Old Feb 19, 2023 | 08:07 PM
Junktownbill99
Good to know, when I flick the switch, (connected to switch, not key) nothing happens, no light, not even a click
Old Feb 20, 2023 | 04:57 PM
Junktownbill99
Looks like I just have a loose connection at the end of the glow plug harness, other than that, all is good! Thanks for the help
Powerstrokin7.3L
Oct 10, 2012 07:02 PM
Hybris
1997 - 2003 F150
Jan 28, 2012 01:02 AM
FordNFishinLover
Aug 5, 2009 11:41 AM
derekmj64
Oct 19, 2008 05:13 PM
unctarheels01
1978 - 1996 Big Bronco
Aug 16, 2004 11:08 PM
