1978 - 1996 Big Bronco
Help with decode please
Old Feb 12, 2023 | 09:05 AM
loyd63's Avatar
loyd63
4wd Low
Ive searched and have not been able to find a decoder for the 1978 bronco vin tag. can someone send a link please..
Old Feb 13, 2023 | 04:45 AM
manicmechanic007's Avatar
manicmechanic007
Leave Bronco out of your search and just use a truck site
Like Blue Oval Trucks
I could not find a link for you but just google "1978 Ford truck door tag decoder" and that blue oval site will be one of several that pop up, and will do the same thing for you
Old Feb 13, 2023 | 08:27 PM
85e150's Avatar
85e150
U15 = Bronco 4x4 Wagon
H = 351 2V (Probably 351M for that year)
L = Michigan Truck Plant
CG----- = 1978 numerical series, July 1978 production
104 = 104 inch wheelbase
6M
6 = Bright Yellow
M = White (Two tone?)
U150 = Bronco, 6,100 lbs GVWR
DZ1 = Interior and body info, I do not have, and can't find it on line.
G = Ford automatic, most likely the C6
16A
16 = Ford 9 inch rear axle, 3,750 lbs capacity, 3.50 ratio
A = Adjustable steering column and Power steering. They don't give other info but wouldn't it be a Dana 44 with 3.54 ratio?
6100 = 6,100 lbs GVWR
1978 = Model year
23 = Memphis District Sales Office
Old Feb 16, 2023 | 02:12 AM
nutter3's Avatar
nutter3
Loyd63,
my 78 has the many of the same features you have. A bigger engine and a little heavier axles is about the only difference i see. What trim is yours? Mine says XLT. But it has round headlights. Not sure if a PO did something to that.
Old Feb 16, 2023 | 10:26 AM
loyd63's Avatar
loyd63
4wd Low
Mine has DZ1 trim, and has square headlights. I was working in a body shop back in the early 80's and I reminder the round and square headlights. I personally like the round better, they put the round headlights in the early 78's and about half the year they started putting the square lights.
Big Kaz72
Large Truck
Dec 7, 2022 07:20 PM
AKBear
Large Truck
Mar 17, 2022 12:36 PM
Jayson Mark
Large Truck
Jul 14, 2020 05:07 PM
JakeK
Mar 4, 2018 05:59 PM
reamer
Mar 21, 2017 07:08 PM
