Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 VIN decoding help
Old Mar 16, 2022 | 07:16 PM
AKBear's Avatar
AKBear
Could someone help me decode this data tag?
Thanks!
Old Mar 16, 2022 | 07:59 PM
85e150's Avatar
85e150
Welcome to FTE!
F61 = F600 gas, 4x2
C = 370 2V gas V8 OR 429 4V gas V8. The 370 is noted as "F600 only". If you have a 4BBL carb, check for an emissions sticker to confirm engine size--if it's still there!
V = Kentucky Truck Plant
DJ1458 = 1979 numerical series (Corrected. Note 1979 model year numbers start at DC0,001, ending at FK9,999)
176 = 176 inch wheelbase
No color code--possibly part of the special order when it's not shown.
F616 = F600 gas, 2WD, 24,000 lbs GVWR
AA8 = AA = Black Vinyl / 8 = 81A Standard Cab
L = Transmatic (Ford rebranded Allison) model AT-540 automatic transmission. The MPC shows this as a 6 speed, but it is a 4 speed. More on that at the end of the decode.
53H
53 = Rockwell (Timken) model H-172 single speed rear axle, 17,500 lbs capacity, 6.17 ratio
H = Ford 12,000 lb capacity front axle. Notes say "Tire carrier w/manual steering-w/Steer-Ease"
24000 = 24,000 lbs GVWR
740814
74 = Seattle Distric Code
0814 = Special Order Number. Besides color, no clue what the special order might be.
Regarding the transmission. The MPC shows this as a 6 speed, all the other info you can find show it to be a 4 speed.
Go through this thread and find the AT 540 decoded. Post 7 and beyond will show Allison info, the Ford MPC, and several other posts from folks who have experience with the AT540.
https://www.ford-trucks.com/forums/1...ssistance.html
Let me know if something doesn't line up or any other question.
Last edited by 85e150; Mar 16, 2022 at 11:32 PM. Reason: correct model year number
Old Mar 16, 2022 | 08:16 PM
AKBear's Avatar
AKBear
Thank you, @85e150, for your rapid and thorough response!
Could you confirm the year of manufacture?
Thanks again for the terrific reply.
Old Mar 16, 2022 | 11:36 PM
85e150's Avatar
85e150
Ooops, got that 1979 off a little. Corrected above.
With the serial numbers starting at DC0,001, your DJ1,458 might have been built in 1978 as production of the 1979 model year trucks began in August of 1978. I do not have the monthly serial number info. You may find build dates on engine castings that read 1978 but it is normal for engine (and other) castings to be months ahead of vehicle builds.
Old Mar 17, 2022 | 12:36 PM
AKBear's Avatar
AKBear
Thanks!
Thank you, again, @85e150. You provide a wonderful service and have given me the answers I sought.
I appreciate your time.
J_Remy
Jun 29, 2021 03:12 PM
55 dude
May 13, 2021 09:42 AM
NewFordOwner234
Large Truck
Apr 20, 2021 07:04 AM
Damen69
Nov 19, 2016 10:28 AM
