F800 VIN Decode Please
Any help is greatly appreciated, Thanks!
F = 391 4V FT engine.
U = Louisville KY Assembly Plant
896189 = 1966.
176" Wheelbase.
No COLOR code, truck painted a non standard color, making it a Domestic Special Order.
F803 = F800 (gas), 25,500 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = Standard Cab.
Q = Dana/Spicer model 5652 5 Speed Direct.
8HD:
8H = Eaton model 17800 or 17801 Two Speed Rear Axle / 7.17/9.77 / 18,500 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
25,500 lbs. Gross Vehicle Weight Rating.
199 net HP @ 3,800 RPM
B11609:
B1 = FoMoCo of Canada Ltd., Ford Central Division.
1609 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
https://www.ford-trucks.com/forums/1...l#post19380857
EDIT: Thread moved and Post copied above.
