I am sure this question has been asked and answered, however I could not find the answer using the search function. Is it possible to add turbo boost in your gauge configuration on a 2022 F250 Lariat? I did search for it in the cluster and IPC module modifications in forscan but did not find it. Thank you in advance.
Are you asking if the turbo boost can be displayed along with the fuel and temperature gauges at the top of the dash display? Yes. You don’t need FORSCAN to do it, it’s in one of the configuration pages in the center screen where you can choose turbo boost, transmission temperature, or def level (if a diesel). It shows on the far right gauge position.
Thank you, I will try again. I looked for it to add under my configuration. I found the Def level gauge. I must have missed it.
Ok, I may be missing something or I am just stupid. I did access the center screen where you can choose as you stated. However all I see is a choice between transmission temperature and def level. Were you able to access all three choices on your 2022? Would the turbo boost option not be available because I added the digital temperature display above the gauges via Forscan? Sorry for the dumb question.
That's strange, the turbo gauge is usually the default gauge from the factory. Adding numbers above gauges would have no effect on the turbo gauge. On my truck I selected to have the trans temp on the dash instead of turbo boost, but I have noticed that after making Forscan changes it will sometimes revert back to the turbo gauge. Never had it go missing.
I guess it is not really missing, it is just not an option to choose from the center screen. I will try again this weekend.
