OME springs 'level kit'
Old Feb 10, 2023 | 12:00 PM
dlatourette's Avatar
dlatourette
Trailering
I used to work for ARB (who sells the Old Man Emu suspension bits) back in the day, and I had purchased front and rear springs for my 2005 F250, but I never installed them. I purchased a 2019 F350 last November, and I disliked the extreme rake (it had a factory 5th wheel package, so I assume even stiffer rear springs?) from front to back. ARB doesn't have any suspension products listed for the 2019, but since I had the OME 2768 front coil springs, I ordered up their fit kits for the sway bar bracket drop, brake line drop brackets, and Panhard rod drop bracket and gave it a try. The sway bar drop brackets work, but I did have to shorten the bolts/studs in the frame. The brake line brackets must have changed in 2017, so they didn't fit. The Panhard rod drop bracket fit, however my axle is moved 1/4" to the passenger side. Usually a level lift moves the axle to the driver's side as the Panhard rod is effectively shortened. I'm going to try going back to the stock Panhard rod bracket next, but I guess 1/4" isn't too bad. The OME 917 coils have eleven windings compared to my original coils' eight (I think), and the wire diameter is about .060" larger. The level turned out just about perfect, though I'm not sure how much it'll be low in back with a trailer.
Last edited by dlatourette; Feb 10, 2023 at 12:46 PM. Reason: corrected part number
Old Feb 10, 2023 | 12:07 PM
JoeUser's Avatar
JoeUser
Ha, I had no idea that OME made lift products for the F250. I've used them for my old FJ Cruiser years ago, they're well made products.
If mine didn't already have a lift I'd consider using OME again.
Old Feb 10, 2023 | 12:09 PM
4wd6.7L's Avatar
4wd6.7L
I have had OME front and rear suspension on a Tacoma, didn't know they made anything for the Super Duty. How is the ride with those coils compared to stock, and how many coil choices do they offer?
Old Feb 10, 2023 | 12:24 PM
dlatourette
Trailering
Here's a link to the relevant page in their product guide:
https://view.publitas.com/arb-4x4-ac...-36/page/92-93
Old Feb 10, 2023 | 12:33 PM
JoeUser's Avatar
JoeUser
Hmm, that PDF only lists up to 2017 MY coverage.
Old Feb 10, 2023 | 12:35 PM
dlatourette
Trailering
Yep, they don't show anything newer, but the springs and some of the fit kits (as outlined above) still fit the later models - they just haven't done any test fitting to update their catalog.
Old Feb 10, 2023 | 12:41 PM
4wd6.7L's Avatar
4wd6.7L
Thank you, good to know. It looks like they have coils that give approx. 2", 3" or 4" lift. Yours must be the 2".
Old Feb 10, 2023 | 12:47 PM
dlatourette
Trailering
Thank you, good to know. It looks like they have coils that give approx. 2", 3" or 4" lift. Yours must be the 2". I don't see an OME 917 on there, when doing a google search the 917 coils show as being for the rear of a Mitsubishi.
I just noticed that. I think I used the 2768 springs. They did give more than 2" of lift. I'm actually hoping they settle a tiny bit.
Old Feb 12, 2023 | 10:24 AM
PlanoRob's Avatar
PlanoRob
Wow, OME, eh? As a former Jeeper, I had my go with them, too! Based on everything I see on this board, it’s easy to think that one must spend thousands on Carli products to get the truck in the air!
Old Feb 12, 2023 | 10:41 AM
dlatourette
Trailering
As a one week update, I've found the OME 2768 coils are definitely more firm than the stockers I had on my truck. The stockers were too soft, though, and allowed the axle to hit the bump stops on freeway rollers occasionally, so I like the change. It's not so firm as to make the ride uncomfortable. I'll be adding Bilstein 5100s this Monday, and I'll be interested to see how those do.
Old Feb 12, 2023 | 10:52 AM
4wd6.7L's Avatar
4wd6.7L
Were your stock coils 5200's? I found the OME 2768 to have a 450 lb/in spring rate and the stock 5200 springs 430 lb/in. Not too much difference. Both the 5600 and 6k spring rates are higher than the OME 2768.
Old Feb 12, 2023 | 10:54 AM
dlatourette
Trailering
I'm guessing they stock coils were the 5200s? The dealer I purchased the truck from did their 'spray everything black' treatment, so the tags are unreadable. However the wire diameter is around .060" smaller than the OMEs.
Hoss86
Jan 30, 2021 05:57 PM
mason97x
Jan 2, 2018 09:55 AM
Big_Zach
Aug 18, 2013 08:07 AM
Powerstrokin_350
Mar 23, 2012 03:17 PM
78fordranger
1978 - 1996 Big Bronco
Dec 11, 2006 10:53 PM
