Sponsored by: Auxito
2000 F-150 Problem Starting
Old Feb 24, 2023 | 08:11 AM
2ManyCars's Avatar
2ManyCars
We checked fuse #21, looked fine, but to be on the safe side, we traded it with another 15 amp fuse. No luck. We tried starting it and moving the shifter through the gears to see if the alignment was off, no luck. I put my probe on the small signal wire and turned the key, no light on the probe, so I don't believe we are getting a signal from the key/steering column. I can still start the truck by using my adjustable wrench and touching the brass lugs on the relay.
Old Feb 24, 2023 | 08:39 AM
projectSHO89's Avatar
projectSHO89
Two things to check:
1. Try shorting the always hot terminal on the starter relay to the small terminal. If the relay is good, it will pull in and the starter will engage. Also makes less of a spark.
2. Check to see if F21 goes Hot in Start. That splits the circuit and narrows the focus.
Old Feb 24, 2023 | 05:10 PM
2ManyCars's Avatar
2ManyCars
We shorted the small terminal to the bottom lug on the relay. Good idea, it started and I didn't see any sparks. Thanks for the suggestion. Ed
Old Feb 25, 2023 | 07:38 AM
projectSHO89
Now, go do step #2.... as well as previously offered suggestions.
Old Feb 25, 2023 | 09:33 AM
leolipert's Avatar
leolipert
Trailering
Are you sure there is no aftermarket alarm installed on your truck? I had the same symptoms as you and the dealer installed alarm was the problem.
Old Feb 25, 2023 | 11:00 AM
projectSHO89
This is true if the add-on system includes a starter interrupt feature. Do need to check this.
Old Feb 25, 2023 | 11:12 AM
manicmechanic007's Avatar
manicmechanic007
All aftermarket alarms have a starter interupt circuit
Yes, he is sure there is an aftermarket alarm, it had a valet switch and an aftermarket underhood siren
Old Mar 3, 2023 | 01:58 PM
2ManyCars's Avatar
2ManyCars
Update - I had bought a remote start switch from autozone a few days ago, 7.99 plus tax btw, and had been using it to start the truck from under the hood until I could figure out the problem. And lo and behold, today my son went out to start the truck and move it under our carport, and it started when he turned the key. This is the first time it has started with the key. I don't have an explanation as to why it worked today and not for the past month. I can't think of anything we changed. Anyway, we are good for now. Thanks to all for your help...
Old Mar 7, 2023 | 10:17 AM
2ManyCars's Avatar
2ManyCars
Update - We were able to start the truck by just using the key the other day, but then the next day, no luck. I can still start the truck under the hood using the remote start switch. So, we have a working solution, but not so elegant. For now, I will start the truck with the switch (if needed), but in the near future, I will try and troubleshoot the real problem. Thanks again to all for your suggestions. Ed
Deerkiller63
Dec 11, 2011 05:02 PM
Dayzer0
Mar 27, 2011 09:47 PM
peter p
1997 - 2003 F150
15
Mar 7, 2007 01:03 PM
skooch
1997 - 2003 F150
Mar 17, 2006 08:17 PM
RedInline6
Apr 8, 2004 08:34 PM
