Turn signal wiring
Old Feb 7, 2023 | 10:46 AM
maxmarble's Avatar
maxmarble
4wd Low
Question Turn signal wiring
I have a 1982 f100. With 3 in the tree and need to put a new plug on the vehicle side of the turn signal connection I have a photo of what I have in the wiring..if anyone has a clue where the wires. Go I would appreciate the help.
The wire colors for the turn signal side are #1 empty, #2 green, #3 blue red hash, #4 orange white stripe, #5 green orange stripe, #6 white red stripe, #7 yellow white stripe #8 green white stripe ,#9 white red hash, #10 dark blue, #11 empty
the attachment list the vehicle wires
File Type: pdf
Old Feb 7, 2023 | 02:54 PM
Franklin2's Avatar
Franklin2
Not sure what your request is. If you know what wire color goes in what slot, what else do you need to know? Here's a diagram of it.
Old Feb 7, 2023 | 03:00 PM
maxmarble's Avatar
maxmarble
4wd Low
The wire colors do not match up an example the vehicle side has no dark blue
Old Feb 7, 2023 | 06:26 PM
Franklin2's Avatar
Franklin2
I guess I am having a bad day or something. Forgive me if I am dense. If your truck does not have a darkblue wire, then why do you want one? All I know is you have a 1982 truck, and are trying to put a 1982 turnsignal switch in place? You are right, I see no darkblue in the diagram above going to the switch, so why are you looking for a darkblue or why do you have a darkblue?
Old Feb 8, 2023 | 04:58 AM
maxmarble's Avatar
maxmarble
4wd Low
The turn signal switch has a dark blue wire in position # 10 as I stated my problem is very simple I have eleven wires hanging down under the steering column . I have a used receptacle because the old one was damaged and had to be removed there were two individuals working on the problem each thought the other made note where the wires went now I’m trying to straighten it out. I apologize form not stating this issue clearly
Old Feb 8, 2023 | 05:51 AM
Franklin2's Avatar
Franklin2
Ok, you are at the bottom of the column. I believe the connector you are messing with is C305. Darkblue goes to the horn. It's in the diagram below. In the diagram below, it says the darkblue wire changes to a yellow/lightgreen hash wire on the other side of the connector.
Old Feb 8, 2023 | 05:56 AM
Franklin2's Avatar
Franklin2
I just noticed in the first diagram I posted, the white/red hash wire from the truck, changes to a red/white hash wire. Be careful, sometimes Ford had typos and errors in their diagrams. But I don't think you can blow anything up, they are all hot wires. The white/red red/white are the hazard flasher feed.
Old Feb 8, 2023 | 07:29 AM
maxmarble's Avatar
maxmarble
4wd Low
Thanks for the help if you come across any others please let me know unfortunately when they made these there were times they just grabbed what ever was available to get it out you know a Friday lat in the day production.
again thanks
Old Feb 8, 2023 | 05:12 PM
Franklin2's Avatar
Franklin2
The others should be the same color wire on both sides correct? Just hook them together or just put them in the same slot on both sides.
Old Feb 11, 2023 | 08:43 AM
maxmarble's Avatar
maxmarble
4wd Low
Thanks I know I’m going to have two extra wires the turn signal has 9 and the vehicle has 11 so now it’s just a matter of getting the right ones thanks again
Old Feb 24, 2023 | 12:22 PM
maxmarble's Avatar
maxmarble
4wd Low
After all is working I have a two wire pin that is white with a purple line and a single light blue wire does anyone know what they are for?
Old Feb 24, 2023 | 12:55 PM
Franklin2's Avatar
Franklin2
No way of knowing. Do the two wires lead up into the column? That could narrow it down some.
Old Feb 24, 2023 | 03:06 PM
maxmarble's Avatar
maxmarble
4wd Low
Yes at the base of the column with all of the turn signals wires
Old Feb 24, 2023 | 07:21 PM
Franklin2's Avatar
Franklin2
The only white/purple I can find comes from fuse 6, and feeds the cruise control, the 4x4 indicator circuit, and the digital clock.
JaspersDad
Mar 7, 2026 01:44 PM
jcjc123
Apr 5, 2022 08:00 AM
ChiefGeek
Apr 18, 2018 05:40 PM
ride31486
May 18, 2009 10:47 PM
stevew15
Apr 8, 2006 02:54 PM
