7-pin trailer connector harness query
Hi,
I have a 1995 F-150 5.0L 4r70w XLT (Eddie Bauer) and I want to install a 7-pin connector to power my trailer brakes. My truck appears to have the towing package as it has the extra relays under the hood attached to the power distribution box, the black and grey connectors under it are plugged in, and out back at the bumper there are black and grey connectors with a total of 7 wires. I checked the wires and the running light, blinkers, switched power, etc all are there.
Did (or does) Ford sell a plug-and-play harness with the 7-pin connector on one end and 2 plugs to connect to those existing plugs? ( I would prefer not to have to hack up the factory harness.)
If so, does anyone have a part # and better yet, a source for the thing?
I found a thread that mentioned a similar harness, but it was only for the flat 4-way connector and not the 7-pin connector.
Thanks in advance!
Thanks in advance!
I'd be up for making my own... where'd you get the 4 pin connectors ?
The connectors are the same as period EGR connectors, so you should be able to source them pretty easily. I bought mine from LMR, listed under one of the mustang sections. I use non insulated butt connectors with a crimping tool and adhesive lined shrink tubing. Other folks prefer soldering.
Yep, I ordered that harness along with the controller, thanks!
johnEboy
04-20-2008 12:34 PM
Arroyo_Runner
08-15-2007 11:31 AM
BLK94F150
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-12-2005 10:31 AM
