Electric Brake Control/wiring Redux
I have an 04 Explorer. It has a class II towing package with a 4 pin flat trailer connector. Thanks to Steina. I spoke with a trailer dealer, 2 RV dealers and a Ford parts department yesterday and all were no help. Yep, remove the glove box and there was the 6 pin brake connection taped to the wiring harness, just like Steina said there would be. The flat 4 pin trailer connector harness runs across the back/top of the hitch and ends in a 8 pin plug/connector. Shouldn't I be able to unplug the connector from the 4 pin trailer outlet and replace it with a 7pin? The Ford dealer parts dept was usless. He basically said that all I can get from Ford is what came with it. Does anybody make a 7 pin outlet that will plug into the factory connection? Will I still need to pull other wires, ie..battery charge to trailer?
My F150 had a harness plug with 7-8 wires that ended up at the frame rail by the left rear tire. from there a 4 pin harness ran to the rear bumper. i figured out which two wires on the main harness i needed for brakes and 12 volt power and extended my own. I had checked on e-bay and there were wiring harness you could buy to replace the 4 pin rear harness and add a 6 or 7 pin rear connector. All the wires should be up front, but you might have to add a relay in the fuse box to get the rear brake controller to work.
you might send this guy a note and ask how it works
eBay Motors: Standard TRAILER WIRE CONNECTOR ford EXPLORER 91-02 01 (item 370038540566 end time May-01-08 07:06:40 PDT)
Steve. Thanks for the reply. To anyone else interested in this issue, I found the following a while ago in another forum. It answers my questions very well. Even has a part number for the 7-pin wiring harness. (its expensive)Summary; 02-05 Explorer Trailer Wiring - Ford Explorer Ranger Enthusiasts Serious Explorations
JohnEboy -
Hope you get the 7-pin wiring installed OK, but here's some info for you in case you're not already aware of it: Even if you swap out your Class II receiver for a Class III/IV, your tow rating remains at 3500# (according to Ford). You'll still be without the 3.73 LS rear gears, and an engine oil cooler (if you have the V6).
Welcome to FTE!!!
Steve
Welcome to FTE!!!
Steve
bossgobbler
10-27-2011 08:18 PM
07F150trucknut
Electrical Systems/Wiring
01-19-2008 03:56 PM
Moonblink
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-14-2004 06:06 AM
