Sponsored by: Real Truck
Black Maxx programming
Old Feb 6, 2023 | 05:19 PM
Kwhurley's Avatar
Kwhurley
4wd Low
I have an 08 f250 and have a black maxx programmer question. The truck was bought with it programmed to performance. The motor had a blown piston and was taken to the shop for a full short block rebuild. While at the shop, they flashed the ecm and put on their own program on it. I have ordered all the cables to re hook up the tuner. Is there any way to recover the lost programming, or can I use the tuner just for monitoring?
Old Feb 6, 2023 | 05:30 PM
ShelbyHauler's Avatar
ShelbyHauler
Is the tune in the programmer? I believe my SCT will hold 4 tunes.
Old Feb 6, 2023 | 05:34 PM
Kwhurley's Avatar
Kwhurley
4wd Low
The tune was erased when they flashed it. The programmer is Vin locked to this truck, so was wondering if I could use the programmer even tho the stock program from the truck has been erased.
Old Feb 6, 2023 | 05:52 PM
ShelbyHauler
I understand they flashed your truck, but you still have the tuner. Flashing the truck should not erase anything from the tuner. From their descriptions of the tuner:
The H&S Black Maxx for Diesel Trucks comes with preloaded tunes for both DPF present and DPF removed trucks. The H&S Black Maxx tuner for Diesel Trucks is capable of removing the DPF and ALL related sensors if desired.
You can check online for updates, new features & free custom tunes!
So you should have something or you can download something, if that service still exists. Even of not, it should still work to monitor your truck.
Old Feb 6, 2023 | 05:55 PM
Kwhurley's Avatar
Kwhurley
4wd Low
I am not really sure how the tuners work. If they lock up if the previous program is not returned to the tuner. The cables were not available to take the tune off and return to stock before they flashed it and put their own program on it. So is the tuner going to store the program that they have installed as the stock location?
Old Feb 6, 2023 | 06:28 PM
ShelbyHauler
Per the little that I read, and hopefully, someone that knows the BM tuner can step in, the tuner has all that it needs built in. My SCT tuner gets the tunes downloaded into the tuner, then it plugs into the vehicle, copies the factory tune, and "copies" or "programs" the ECM with the code that is in the tuner. That data or tune remains in the tuner as well as in the truck.
Again, I do not know the BM tuner so I have no idea how to check what is in it, or how it really works.
Ok, so I just googled how to use the BM tuner, and found this. I think this will answer all your questions.
Old Feb 6, 2023 | 06:54 PM
Kwhurley's Avatar
Kwhurley
4wd Low
Thank you for all the guidance. I will update when I get the communication cables in. I just dont want to flash the ecu and the program not load to it since it already has another custom tune on it.
Old Feb 6, 2023 | 07:01 PM
ShelbyHauler
I take no responsibility for what/why the shop tuned your tuck with or what may happen if you change that tune. I would talk to the shop and see if there is anything special about the tune they installed and if using the BM tuner will have any ill effects.
Old Feb 6, 2023 | 07:04 PM
Kwhurley's Avatar
Kwhurley
4wd Low
I really dont trust the shop that did the work to be honest. When I picked the truck up, he said the tuner was a paper weight.
Old Feb 8, 2023 | 08:25 AM
speedfreak78's Avatar
speedfreak78
Did they charge you more for "their" tune/tuner?
Sounds like the shop either doesn't know your tuner, or more likely, just wanted to push their product, rather than trying to make yours work.
bandolero23
Sep 10, 2013 09:57 PM
Jordan123
6.4L Power Stroke Diesel
Jun 17, 2012 01:04 AM
SHAWN056.0
Jul 19, 2009 01:38 AM
viperbluelx
Jan 8, 2008 10:56 AM
2004SUPERDUTY
Oct 31, 2007 04:49 PM
