Windshield Sprayer Pump
Old Feb 6, 2023 | 02:38 PM
christempel's Avatar
christempel
4wd Low
Hello, Hoping to find some more help with my 93 F250 XL.
I bought the truck knowing that the sprayer for washer fluid didn't work. The previous owner said it was just a bad pump/motor. I removed the motor (it was pretty corroded), I bought a new one at Napa, installed it, and it still doesn't work. I can verify that the motor isn't receiving a signal as I removed it and hit the washer button and tried to see if it was spinning. It wasn't.
When I hit the sprayer button, I can hear a "click" on the passenger side of the cab, inside, where the wires and fuel cut-off are located. So best I can figure, the signal is going from the steering column button to some relay or switch on the passenger side, but not to the motor itself after that.
Where should I start looking to trouble shoot this? It's winter here in Montana and I'm having to keep a spray bottle of de-icer in the truck and stop to spray down the windshield when it gets bad.
Thanks in advance!
Old Feb 6, 2023 | 03:36 PM
jas88's Avatar
jas88
You should first use a test light to see if there is power at the plug when you press the washer button.
redrock5.9
Aug 9, 2022 12:53 PM
gmammakn
Mar 23, 2017 09:38 PM
bakerbuilttracks
Apr 13, 2016 08:14 PM
mr.fordneck
Oct 31, 2013 10:43 PM
BigArn
Sep 13, 2004 09:20 PM
