1994 Explorer auto lockouts
Old Nov 14, 2003 | 09:00 PM
samo1056's Avatar
samo1056
Hello,
I have a 94 Explorer with many miles but still in great shape.With winter coming I have a problem with the auto lockouts engaging and disengaging. I really do not have the cash to change out to manual lockouts do any of you know of a soluntion to help with the problem.Is there a rebuild kit or some thing I can check out in the system?
Thanks Samo
Old Nov 15, 2003 | 01:58 PM
Evicerate's Avatar
Evicerate
I don't know much about the hubs, but if you search the forum for auto hubs ratherthan lockouts you might get better results. Here's one I found for you though:
https://www.ford-trucks.com/forums/s...ht=%25252Bhubs
Old Nov 15, 2003 | 02:28 PM
golfboy17's Avatar
golfboy17
Are you sure its the hubs??? Does the 4x4 light come on.....because theres a very common problem in the 91-94 explorers with the shift motor......it gets dirty and wont work......its real ez to do yourself take you about an hour hour and a half, let me know and i will send the the link that tells you exaclley how to do it along with pictures
Old Nov 15, 2003 | 06:37 PM
samo1056's Avatar
samo1056
Thanks for the info,
I do believe hubs are a better chioce of word than lockouts. And the 4x4 light does light up I believe the hubs just dont engage properly.
Old Nov 15, 2003 | 07:48 PM
golfboy17's Avatar
golfboy17
YEA if the light does come on then the hubs are not locking....try ebay sometimes you can get cheep used hubs or a junk yard
Old Nov 16, 2003 | 09:45 AM
Evicerate's Avatar
Evicerate
Maybe you should read the posts that have stuff like no 4x4 engagement, etc. I cleaned the transfer case motor like some of them said and I now have 4x4 again. I don't know how to diagnose hub probs, but my light came on and 4x4 didnt work, cleaned the motor, bam, 4x4.
If it is indeed the transfer case motor it'll cost you like $5 for stuff to clean the parts, and maybe even less if you have stuff already.
Old Nov 16, 2003 | 11:15 AM
golfboy17's Avatar
golfboy17
I remeber reading a forum here and it told you how to test the hubs to see if there goo or not, i would search it and see what you find.....i think it was something like you jack up the front of the car, and sping th front driveshaft i dont remeber waht you do after that
breakstuff
1983 - 2012 Ranger & B-Series
Oct 10, 2014 10:22 AM
spow1998
Feb 22, 2011 07:03 PM
jerrytown2001
Apr 21, 2008 06:57 AM
shultz
May 27, 2004 02:35 AM
samo
May 18, 2004 06:58 PM
