6.7 transmission temperature
Old Feb 6, 2023 | 05:21 AM
dutch71's Avatar
dutch71
Certainly it's already been discussed but I can't seem to find it in the threads.
I'm at my first SD with 6.7 power stroke. From time to time I happen to haul quite a lot of stuff in the bed. Having no experience with this engine I'd like to ask your experience on transmission temperature, driving on flat or high grades for instance, what's a safe temp range to keep the transmission at.
Thanks
Old Feb 6, 2023 | 05:27 AM
Wyldfire's Avatar
Wyldfire
Thanks
They run hot by design.
Old Feb 6, 2023 | 05:43 AM
Wyldfire's Avatar
Wyldfire
Ford considers normal operating temp of transmission is 190 to 260. I can see 245 pulling and climbing regularly. Never has caused an issue.
Old Feb 6, 2023 | 06:34 AM
senix's Avatar
senix
I seem to run around 200-210 unloaded and around 220 on averge pulling. 240 mountains heavy towing.
cooling stragey in mine is pretty agressive and I never see coolant temps over 220 and oil temps at 225 kicks the clutch fan on high.
Old Feb 6, 2023 | 08:53 AM
RidgwaySD's Avatar
RidgwaySD
There is nothing you can do to "control" the temp, it is a function of the vehicle. Being "concerned" about this is wasted energy.
Old Feb 6, 2023 | 09:16 AM
HRTKD's Avatar
HRTKD
My engine oil temperatures haven't exceeded 245°F and my transmission temperatures haven't exceeded 235°F. I tow an 11K toy hauler over Rocky Mountain passes.
If you're worried about it, slowing down can help a bit. Going too slow can also be a problem. I've seen my temps do some strange things when pulling up the other side of the Ike Gauntlet in stop and go traffic.
Old Feb 6, 2023 | 11:18 AM
redford's Avatar
redford
FTE Leadership Emeritus
If your coolant, oil or transmission gets too hot, your truck will tell you. No need to focus on it. Follow the severe duty schedule and relax. Don't take the enjoyment of driving away by worrying about everything. Enjoy your Super Duty.
Old Feb 6, 2023 | 12:00 PM
dutch71's Avatar
dutch71
Thanks everyone for your feedback.
shaneprice56
Nov 30, 2023 07:29 AM
czufelt
All Things Towing
Oct 5, 2021 11:45 PM
obscurity
Jun 10, 2013 10:32 AM
workingdog
Aug 11, 2006 11:36 PM
RCsanjose
Jul 23, 2003 11:20 AM
