Sponsored by: Real Truck
Abs non response
Old Feb 3, 2023 | 10:21 AM
Aaronb21's Avatar
Aaronb21
2nd Gear
Abs non response
Hello, my 2005 ford f 350 recently started having abs problems. Right now the check engine light is on for PO500 the VSS code and the abs light is on all the time, the tow haul light is constantly blinking while driving and the speedometer does not work. I have already changed the VSS and that did not help. I have used a code reader and my abs module is not responding at all. I noticed the 2 60amp fuse were both blown and looked like they were burned a little bit on the bottom
this is a diagram that I was able to get. The 2 60a that should get power at all time are not getting any power. The 10a is still getting power. Any help or idea maybe grounds to check or possible wires to check is helpful. Thank you- Aaron
Old Feb 3, 2023 | 08:46 PM
Djosbun's Avatar
Djosbun
Pull the fuse block out and check the underside for corrosion.
— Dave
Lroberts
Large Truck
Jan 20, 2020 07:38 PM
earl964
Nov 16, 2007 10:23 PM
squeals99
Apr 17, 2006 08:53 PM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
