No spark
Old Feb 1, 2023 | 04:43 PM
  #31
Anonymous12's Avatar
Anonymous12
Rotor spins when cranking.
Old Feb 2, 2023 | 04:21 PM
  #32
Anonymous12
Update, it started. The solenoid caused the no spark.
Old Feb 2, 2023 | 10:53 PM
  #33
Prototypemech's Avatar
Prototypemech
Which solenoid? The starter solenoid?
Old Feb 2, 2023 | 10:55 PM
  #34
Anonymous12
Yea, replaced the solenoid to fix the cranking by itself. I go to test the solenoid to see if it cranks, and it starts to fire, ran perfect.
Old Feb 2, 2023 | 11:14 PM
  #35
Prototypemech
Ummm. That's not right. The starter solenoid has nothing to do with the ignition system.....but...
Ford uses the starter solenoid as a terminal block for the main cab power wires, and a broken wire or burnt fuseable link may have been disturbed enough to connect and start working again.
You should take a close look at those wires and fuseable links for damage before you drive it farther than you're willing to walk home.
Old Feb 3, 2023 | 12:40 PM
  #36
Anonymous12
I’ll take a look at all that.
woot56
Mar 14, 2022 03:38 PM
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
Feardeere7
19
May 8, 2014 08:22 AM
DictatorDanny
General Automotive Discussion
20
Feb 9, 2005 10:20 PM
