Remove lift, install v code, what shocks?
Old Jan 23, 2023 | 01:25 PM
rickerbreard's Avatar
rickerbreard
1st Gear
Hello,
I have scoured this forum and thought I had found my answer. After checking with shock surplus I am more confused.
I am wanting to remove a 3" rough country lift on my excursion and go back to "mostly" stock with bilstein shocks and v code springs. (I am still wanting to fit my 295 tires)
I read on here that the correct 5100 springs are:
Front: 33-187297
Rear: 33-236964
Shock surplus says that rear shock is for a 4" lift.
Does anyone know if that is the correct rear shock? Thanks,
Old Jan 24, 2023 | 02:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Not a 5100 listed that fits a stock height excursion.
if you must have a Bilstein you can us a 4600 series.
but for a stock height Ex on stockish size tires I like the KYB MonoMax. Same mono tube construction, Similar valving profile and quality as the Bilstein but priced more agreeable.
Old Jan 25, 2023 | 07:16 AM
solyoung's Avatar
solyoung
The V-code springs are going to give you a lift. There are a few options for height and stiffness with the various Superduty springs. Do some searches through the forum and Google to get a list of heights and weights for those, and then pair that with the right 5100 shocks. If you look at Bilstein's or most other 4x4 websites carrying the 5100s, they list the lift height for them. It's pretty straight forward...
1. Pick the springs
2. Match the 5100s
3. Crack a beer and bust your knuckles
christian.lewis
Mar 17, 2022 02:13 AM
grumpyinme.
Mar 21, 2018 05:13 PM
rally68
Mar 26, 2016 12:35 AM
Bluzilla
Jun 7, 2012 09:56 AM
pdqtimetrialer
Apr 26, 2010 07:18 PM
