Sponsored by: Real Truck
Cab swapped along with VIN
Old Jan 22, 2023 | 06:02 PM
2002cclb's Avatar
2002cclb
1st Gear
I recently bought a 2002 F-250 and discovered the title is for a 2004 F-350, however the VIN on the truck matches the title. The seller's explanation was that the cab was replaced by a previous owner and the title was changed through the state (Michigan). It is a green title, not "salvage" or "assembled". Obviously it didn’t start off under that VIN when it was new so it must have been officially done right? I guess what I'm wondering is, is this the way it should be done? Right now it is insured as a 2004 F-350. I have been told by multiple people in the industry that if the title matches what's under the glass, it's ok. Is that really the case? Thank you for any help in advance.
Old Jan 22, 2023 | 06:14 PM
2001F350dualwheel's Avatar
2001F350dualwheel
I always thought it was illegal to vin swap. That’s how Boyd Coddington got in trouble. Normally a vin follows that vehicle for life. When it’s disassembled and crushed at a junkyard the DMV is notified it’s been crushed. FYI a VIN umber can also be in multiple various locations on a vehicle not just under the glass
Old Jan 22, 2023 | 08:02 PM
Old and soft's Avatar
Old and soft
Wouldn't the vin follow the cab with the tag riveted on the dash? I know air cooled beetles have the vin stamped on the wish bone, title follows the pan, not the body.
Old Jan 22, 2023 | 08:12 PM
2001F350dualwheel
Right…for THAT cab. Taking as in removing the VIN from one cab and moving and mounting it it to a different cab is what is actually illegal. A VIN follows the original vehicle it was assigned to by the manufacturer. Maybe Michigan laws are different…..but you can’t have a 2002 vehicle that has a 2004 title. If that’s the case where is the 2002 VIN and title? It can’t just disappear.
i stay away from any vehicle that has a muddy title. But that’s me.
Old Jan 23, 2023 | 12:22 PM
GN1220's Avatar
GN1220
Call your local highway patrol and they will give you the facts regarding VIN tags/titles in your state.
Old Jan 23, 2023 | 03:54 PM
user 195474726373's Avatar
user 195474726373
Highway patrol sounds like good advice but you might also ask someone at a body shop who has done this type of work.
Old Jan 23, 2023 | 04:11 PM
Dan V's Avatar
Dan V
In MN the vin follows the cab. But if you put an '04 cab on a '02 frame, you're really required to have it inspected, then the vehicle would be considered reconstructed and the new title would reflect that.
FYI, there is a VIN on the frame, which, if discovered can cause a problem....seeing that they don't match.
Old Jan 23, 2023 | 04:36 PM
OverheadCram's Avatar
OverheadCram
I have done quite a few cab swaps over the years as an ASE certified shop and the states the trucks are primarily titled in (CT, MA, NH, NY, RI, and VT) all require the vehicle to legally have a rebuilt title. Those are the states im aware of, but my bet is most will be the same. I highly doubt anyone is going to investigate if you just register the truck as an 04 with the title you have, but im not a legal advisor on the matter.
Some other information, when I turn a truck in for scrap they always require proof of ownership for the cab and bed. I purchase a lot of trucks from the auctions and use them for parts, I never register the trucks and the only way the yard will take the cab or bed whole is with a title or registration in my name. I can turn a chassis in no problem though.
Toolslinger
Oct 30, 2019 10:25 AM
Robb J
Sep 22, 2010 12:09 PM
Jon Hess
24
Mar 13, 2010 09:04 PM
ford0625
13
Oct 9, 2008 11:17 PM
bremen242
Aug 18, 2003 08:34 PM
