Need help decoding VIN....
Old Oct 26, 2007 | 07:20 PM
ford0625's Avatar
ford0625
Hey guys, I need some help decoding this VIN number. Every VIN decoder I have tried said this VIN isn't right, but the guy says it's a one owner truck. It's a 1975 F350. Here is the #:
F37MCW42744
Old Oct 26, 2007 | 07:45 PM
Mil1ion's Avatar
Mil1ion
F37 = F350 Chassis Cab
M = 390 4v
C = Ontario Truck Plant (Oakville)
W42744 - Consecutive build number (February 1975)
Old Oct 26, 2007 | 07:55 PM
ford0625's Avatar
ford0625
Hey Dennis,
If this is a Factory cab/chassis truck then can it still be a factory crew cab like he says?
Old Oct 27, 2007 | 10:26 PM
masterbeavis's Avatar
masterbeavis
Does the VIN on the frame match that on the door? It should be on top of the passenger? frame rail, in 3 different spots. Break out the putty knife and wire brush, between the firewall, and radiator support.
Old Oct 27, 2007 | 10:37 PM
ford0625's Avatar
ford0625
According to the guy that owns the truck all of the VIN #'s are matching. Here are the codes on the door if that will help: WB: 167, Color: F, Type: F377, GVW: 3BG, Body: A, Trans: D, Axle: 6J
In the past any factory crew I ran came up as F350 Crew Cab, not F350 cab & chassis. So that threw me a bit.
Old Oct 28, 2007 | 08:36 AM
mudder460's Avatar
mudder460
hey Mil1ion, can you tell me what month this truck was built in? I am tryin to figure out if it was the pre 77.5.
f14bny56245
thanks
Old Oct 28, 2007 | 12:15 PM
Mil1ion's Avatar
Mil1ion
Yes it is... the cut-off build date code is Y80,001
There is another build code cut-off of 20,001 buit I can't remember what that is for.
Maybe steering assist rams ?
Y56245 = April 1977
Old Oct 29, 2007 | 04:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The GVW you listed is actually the Body code, the Body code is actually the Trans code, the Trans code you listed is part of the Axle code.
WB: 167 = 167" wheelbase
Color: F = Dark Ginger Metallic
Type: F377 = 1974/75 F350 Cab & Chassis ~ 10,000 lbs. GVWR ~ With Dual Rear Wheels
Body: 3BG = 3B = Heavy Duty Black Vinyl with Ginger Appointments / G = Custom Cab without back of cab equipment. 81A Crew Cab
Trans: A = New Process 435
Axle: D6J = D6 = Dana 70 ~ 3.73-1 ~ Limited Slip ~ 7400 lbs. GVWR / J = With Power Steering
The truck is an F350 Dual Rear Wheel, Cab and Chassis Crew Cab.
Old Oct 29, 2007 | 05:29 AM
NumberDummy
Axle: D6J = D6 = Dana 70 ~ 3.73-1 ~ Limited Slip ~ 7400 lbs. GVWR = This should read 7400 lb Rear Axle Capacity/ J = With Power Steering
Corrected a mistake...it was too late to edit the original post.
Old Mar 14, 2008 | 02:34 PM
dtumlin's Avatar
dtumlin
1979 vin
I need help figuring out the year model of a Ford truck serial number F15GUFC1815, can anyone tell me what year it is? Also where can I find the information so I can send to title department to vertify the year.
Old Mar 16, 2008 | 02:16 PM
76f350spercamprspeal's Avatar
Hey dtumlim, Here you go!
Your VIN number: F15GUFC1815
Your Model Year is 1979.
Truck Series: F150 2 Wheel Drive
Engine: V8 - 302cid, 2BBL carb, 154 HP
Assembly on: Louisville, KY
Hope this helps!
Old Mar 16, 2008 | 02:44 PM
Mil1ion's Avatar
Mil1ion
I already answered his question in his own thread
https://www.ford-trucks.com/forums/7...ies-truck.html
Old Mar 16, 2008 | 03:23 PM
Sorry I did not know you already answered his question I was just trying to help someone out.
Old Oct 9, 2008 | 11:17 PM
steven86f250's Avatar
steven86f250
I also have an f377. Is this still considered a one ton since it is an f350?
canyoncat
Large Truck
44
Jan 21, 2022 06:56 AM
dbyrd342
Nov 16, 2016 11:44 AM
Will237
1947 and Older Ford Trucks
Apr 4, 2016 12:35 PM
thinkbink
Dec 14, 2015 08:09 AM
tmcquaw
28
Sep 6, 2014 08:03 PM
