Just bought 4 cyl 2012 Escape XLT. Plan to do electrical work and want to disconnect battery first. Does anyone know if this model Escape uses a radio code? If so, is there any way to find the code before disconnecting the battery.
I have a '12 with the 3.0L, but the rest of the vehicle is the same as yours. I have replaced the battery a couple times and never had the need for a radio code.
Were you planning to change the radio? I would think that might require a code, but simply removing the battery shouldn't cause an issue. Never has for me.
Thanks, I'll go ahead & disconnect the battery. On my 2008 Accord I have to enter a code to get the radio to work again after disconnecting the battery so I thought the Escape might have a similar requirement.
