360 Engine Removal
Old Jan 28, 2023 | 10:33 PM
JEFFFAFA's Avatar
JEFFFAFA
Sounds to me like the trans and engine are binding at the dowels. The trans should be supported at the same angle as the engine is currently. Straight from the front of the crankshaft all the way to the transmission's output shaft. So try supporting the trans at different spots. The 4 speeds are HEAVY. Once all the bellhousing bolts and the inspection cover are removed, try installing longer bolts in the outer edge of the bell housing to act as a guide and support.
MyFlattyFord
27
Dec 28, 2022 04:41 PM
FORD~
Oct 22, 2014 09:34 PM
Fish812
May 28, 2011 05:02 PM
F250racer
Dec 5, 2008 08:36 PM
ford390gashog
Jul 1, 2004 11:30 PM
