Brake Controller
Old Jan 16, 2023 | 05:00 PM
sailorman3's Avatar
sailorman3
Brake Controller
( I did post this in the towing section but am hoping to get a faster response here. Thanks)
I have a 2017 F150 with the OEM brake controller. If I use the controller manually, brakes will come on no problem. If I use the brake pedal, it will only give me one bar of gain which gives me little if any braking power. The fuse by the footwell for the module is good. The fuse under the hood for the module is good. The gain is set at 8 and the force is set for moderate. I’ve cleaned both connectors, the one on the truck and the one on the trailer. At this time I am by myself so I cannot test the brake wire voltage coming out of the trailer to see if it varies What else can I do or look for at this time?Thanks
Old Jan 17, 2023 | 06:15 AM
Olds64's Avatar
Olds64
If you have a multimeter with clip leads you can test the voltage by yourself. Just set up your multimeter and use your phone or a digital camera to take a short video while you depress the brake pedal. Sort of a pain but it would give you more info.
Some multimeters even have a hold function that will retain the last reading until cleared.
Old Jan 17, 2023 | 11:42 AM
99powerstrokedF250's Avatar
99powerstrokedF250
1st - what speed are you testing your brakes at? If I recall this is a proportional brake controller, meaning it applies harder as speed increases, to give you an 'even' stop instead of the 'jerk' feeling of the old pendulum style controllers. Turning the gain up will make the trailer brakes apply harder, but they still apply proportionally to your truck brakes, specifically to alleviate the 'jerk' feeling. 0
2nd - what kind of a trailer is this? If it's an RV or even a light-duty (less than 10k) flatbed or utility trailer, you'll likely want it set for 'light electric', not 'moderate.' 'Moderate' would be for an equipment trailer, with a heavier-duty braking system.
Old Jan 17, 2023 | 01:25 PM
sailorman3's Avatar
sailorman3
Thanks for the reply. I’ve got everything straightened out now. It was a cargo trailer and the brakes were out of adjustment. Once I got it adjusted, and the controller set up properly, the gain on 6 and effort at moderate, it’s hard to tell the trailer is back there during breaking. Thanks for your reply.
Old Jan 20, 2023 | 09:32 AM
99powerstrokedF250
That will also cause you major issues. Glad it got squared away.
Old Mar 13, 2023 | 12:13 PM
220KF250's Avatar
220KF250
I'm having an issue with my '05 F250 S/D diesel. Intermittently, the brake lights will come on and the Tow/haul controller will squawk --- without me stepping on the brakes, and not towing a trailer. I believe this may also occur when I am towing a trailer. I had the bed off the truck last week and all the rear wiring checked for shorting and corrosion. The dash odometer and trip meters are not working --- most of the time. If they were, I'd get a report "Check trailer wiring", or words to that effect. I'm wondering if I have a bad controller, light switch, brake switch or dash circuit board.
Any thoughts?
Old Mar 13, 2023 | 12:55 PM
JKBrad's Avatar
JKBrad
Any thoughts?
You might get a better answer in the Super Duty forum. The first place I would check is for bent or corroded pins in the plug itself.
Old Mar 13, 2023 | 07:03 PM
220KF250's Avatar
220KF250
Thanks, Brad!
I tried to copy and paste my inquiry, but got lost. I'll try and research my destination further, later.
sailorman3
All Things Towing
Feb 20, 2023 05:54 AM
Hyakkimaru
20
Nov 3, 2022 05:33 AM
StanleyZ
6.7L Power Stroke Diesel
Dec 21, 2016 09:44 PM
Idle speed
Dec 17, 2013 09:32 AM
derekmj64
22
Mar 7, 2010 07:14 PM
