Brake controller. Which one and where?
Old Oct 8, 2022 | 10:28 PM
Hyakkimaru's Avatar
Hyakkimaru
One of the previous owners of my truck, I know three of them, put the trailer brake controller in a bad spot where the brake pedal sometimes gets caught on the wiring. I could zip tie it out of the way or I could put the brake controller in a better spot. Short video where mine is.
https://youtu.be/Urvk7Ehad8k
Also, the one on my truck currently appears to be a cheaper one. Most of the trailers that I use don't have brakes but the one I'm about to buy does. So I want to make sure I have a good brake controller mounted in a nicer spot. Is the one I have okay or should I buy a new one? If so where should I put it?
Old Oct 9, 2022 | 06:30 AM
Dan V's Avatar
Dan V
Prodigy or Ultima
Old Oct 9, 2022 | 06:44 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Prodigy P3 with OEM adapter has been working great for my application.
Old Oct 9, 2022 | 08:06 AM
Tpayne621's Avatar
Tpayne621
Prodigy p3 is about the best one you can get.
Old Oct 9, 2022 | 10:04 AM
ScaldedDog's Avatar
ScaldedDog
Prodigy P3 in the cubby.
Mark
Old Oct 9, 2022 | 10:34 AM
Kwikkordead's Avatar
Kwikkordead
I use an older Prodigy as well. The old style with the manual lever on the bottom. Still works great.
Old Oct 9, 2022 | 07:46 PM
Hyakkimaru's Avatar
Hyakkimaru
The prodigy P3 looks like a good controller but I didn't really want to spend $170. That's Not including the adapter that Sous is talking about. I might move this down the list a little bit. I don't even have my new trailer yet anyway so, I don't really need trailer brakes at this moment and even if I did, the one I have works I'm just worried that it's a cheap one that won't last or might just quit one day. But I probably will move this down the list a little bit. I didn't know they had gotten that pricey. I'm sure it's plenty worth it, just not quite what I expected. Seems we have a pretty clear winter on what controller to get though, and I appreciate everybody's input.
Old Oct 9, 2022 | 08:03 PM
RacinJasonWV's Avatar
RacinJasonWV
Hmm. The Prodigy P3 sounds popular. I had to look it up. I know what I’m buying if I ever need another!
I’m running the same brand as the P3. It came in the truck when I got it. Maybe an older version of the P3?
Anyhow, I learned (after way too long) that it needed to be level to work properly. Works much better once the instructions are followed. In my defense I didn’t install it. Just thought I’d throw my lesson learned out there in case you want to check the directions for your current controller.
Noticed the P3 says self leveling.
Old Oct 9, 2022 | 08:17 PM
Tpayne621's Avatar
Tpayne621
You can get a p3 on Amazon for $132 and free shipping if you have prime.
The p3 can be mounted anyway at a angle or flat. Lot of the older styles have to be mounted perfectly flat to work correctly.
Old Oct 9, 2022 | 09:01 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I liked the cubby hole too much to give it up for a trailer brake controller.
This old Tekonsha Sentinel never objected to the pitch angle of the oem lower dash panel it is adhered to.
The factory interface harness that plugs and plays into the truck wiring harness is readily and commonly replicated and available in the aftermarket.
Old Oct 9, 2022 | 09:19 PM
BWST's Avatar
BWST
Got Data?
I'm one of the few that is not having good luck with the P3, due to excess vibration where it is mounted. I have not discovered any loose screws or brackets that might contribute to the issue.
If you pick up a P3, ensure you have a stable mounting location. Lower or higher than where I put mine is more stable in my tests.
Old Oct 10, 2022 | 01:23 PM
Paul_R7.3's Avatar
Paul_R7.3
At the risk of adding a comment that doesn't help the OP choose a new unit, I will add....
Me to!
Old Oct 10, 2022 | 03:35 PM
WNYPSDguy's Avatar
WNYPSDguy
I’ve got the Tekosha Primus iQ and its a perfect friction fit for the small cubby in the upgraded 05 dash that pairs with the aux switches. It’s a great spot to reach in case you need some brake boost. I cut a hole in the back of the cubby to run wires thru.
Old Oct 10, 2022 | 03:58 PM
Tpayne621's Avatar
Tpayne621
Old Oct 10, 2022 | 04:20 PM
Sous's Avatar
Sous
FTE Emeritus
If you fellas keep posting pictures of your 2005 dash bezels... My PMS may come out of remission...
