1981 F100 L6 Electrical Problems
Old Jan 16, 2023 | 02:27 PM
Luke0701's Avatar
Luke0701
3rd Gear
This is my first project truck and I got it running but I noticed the starter solenoid was smoking so I took the negative cable off the truck to stop it and it sparked and I wasn’t able to put it back without it sparking a lot. I replaced the battery cables, start, solenoid and voltage regulator. I was wondering if getting a new alternator and voltage regulator connector would solve my issue.
Old Jan 16, 2023 | 02:33 PM
Franklin2's Avatar
Franklin2
What is your problem? Sparking when putting the battery cable on is not necessarily a problem, unless the battery keeps going down.
Old Jan 16, 2023 | 02:36 PM
Luke0701's Avatar
Luke0701
3rd Gear
It’s a big enough spark enough if you just touch the negative cable to the post it’ll weld itself and you have to pull it off with more force
Old Jan 16, 2023 | 02:45 PM
Franklin2's Avatar
Franklin2
So you have a large amp draw somewhere.
The key is not on?
The headlights are not on?
You didn't say it was trying to start?
You could put a testlight between the battery negative and the battery negative terminal for testing. Put the negative terminal on a rag, and poke it with a testlight. Take the alligator clip end of the testlight and clip it to the battery negative. If the testlight lights up bright, you do have an excessive draw. So then you can go around disconnecting things till you find what makes the light go out. Make sure you have a older style testlight with the conventional bulb, not one of those fancy LED testlights.
You can pull the fuses one at a time, pull any wires off the battery for added electrical stuff, and one thing you can pull wires off is the alternator. Do this one at a time till the light goes out. When it does, that is the culprit.
Old Jan 16, 2023 | 02:46 PM
Franklin2's Avatar
Franklin2
P.S. Make sure you close the door when doing the tests. The domelight will be a draw and make the testlight come on, fouling the test.
Old Jan 16, 2023 | 02:57 PM
kr98664's Avatar
kr98664
I noticed the starter solenoid was smoking…
I replaced the battery cables, start, solenoid and voltage regulator...
Did you replace all those parts before or after the smoking relay problem? Unless you’ve got a money tree in your backyard, I’d suggest figuring out the root cause before throwing any more parts at the truck.
Aftermarket starter relays have a VERY high failure rate. Maybe start by installing a top quality name brand relay and go from there:
https://www.ford-trucks.com/forums/1...i-mean-it.html
1975FordF250
Jun 28, 2014 05:21 PM
sherlock375
Apr 30, 2010 09:29 PM
robins79 custom
1978 - 1996 Big Bronco
Oct 14, 2006 01:29 PM
Devildragon
Electrical Systems/Wiring
May 30, 2006 03:50 PM
Devildragon
1966 - 1977 Early Broncos
May 30, 2006 03:48 PM
