2003 f250 V10 4x4 crew cab. Looks like my radiator has sprung a leak from bottom corner and need to replace. Any suggestions on what radiator I should go with?
Found this: https://www.radiatorexpress.com/product/radiator/ford/2003/f-250%20super%20duty/base/68l-v10/218053/1414842?gclid=EAIaIQobChMImdrX3uPM_AIVrBXUAR0EmA35
having a hard time shorting the link but it gets you there. From radiator express all aluminum for like $375
Last night I was watching a YouTube video by FordTech Makuloco whom I totally trust. He says if you can't afford OEM then buy Spectra Premium. I have full confidence in his judgement.
2 days after I purchased my 2008 F250 I noticed a few drips on the ground, the radiator was leaking from the endcap. Reviewing my Carfax showed the truck was on it's third stock radiator. I bought a Mishimoto radiator and their front crossmember to replace the magnesium one that comes with the truck. It is a common belief the flexing and movement of the frontend leads to failure of the plastic ended radiator. The new all aluminum radiator is designed to be rigid and more efficient than a stock unit. It comes with heavy duty bumpers and a lifetime warrantee.
