Steering gearbox replacement
Old Jan 16, 2023 | 01:08 PM
Dave Stevens's Avatar
Dave Stevens
4wd High
I am going to be replacing the steering gearbox on my 1989 f150. It is a 5 speed manual transmission with a 5.0L V8 engine. After watching some YouTube videos I have a good idea on how to swap out the gearbox but I am bit unsure about the fluid. One video said not to use power steering fluid and instead he used Type F automatic transmission fluid. When he swapped out the steering box, he just topped the fluid off. I wanted to see if anyone can confirm if that would be the correct type of fluid to use. Also would it beneficial to drain all of the old fluid out and replace it with new fluid? If so, could anyone give me some tips so that I can have a better idea of what type of tutorials I should be looking for. Thank you.
Old Jan 16, 2023 | 01:46 PM
sandymane's Avatar
sandymane
Type F is listed as Auto Trans fluid and Power Steering fluid.
"><img src=" /> ">
Genuine Ford Fluid XT-1-QF Type-F Automatic Transmission and Power Steering Fluid - 1 Quart"><span style=Genuine Ford Fluid XT-1-QF Type-F Automatic Transmission and Power Steering Fluid - 1 Quart" /> Genuine Ford Fluid XT-1-QF Type-F Automatic Transmission and Power Steering Fluid - 1 Quart">Genuine Ford Fluid XT-1-QF Type-F Automatic Transmission and Power Steering Fluid - 1 Quart
THIS IS FROM THE RED HEAD STEERING BOX COMPANY ON WHAT TO DO TO A "NEW" STEERING BOX. I BOUGHT ONE FROM THEM AND FOLLOWED THESE DIRECTIONS AND THEY WORKED FINE.
How do I purge air, or bleed, my steering gear box system?
  1. After installing the gearbox, fill the system with fluid.
  2. Raise the front wheels off the ground, DO NOT start the vehicle.
  3. Work the steering wheel back and forth, lock to lock, 15-20 times.
  4. Leave the vehicle sit (overnight is best) AT LEAST 2 hours
  5. Top the pump reservoir off again.
  6. Work the steering wheel back and forth again 7-10 times
  7. Have a person in the vehicle and another at the pump reservoir with a container of fluid & funnel ready to pour if necessary.
  8. Instruct the person in the vehicle to start the engine. As soon as this happens, if the fluid level drops, be ready to pour in more fluid. The level must be kept at an almost full level or it will suck in air again.
  9. If this procedure is followed properly, the air problem will be solved.
Old Jan 16, 2023 | 02:08 PM
Encho's Avatar
Encho
The Southernmost Mod
Hello there, check the Steering Box Rebuild link in my signature for a complete procedure on how to work on the steering box. The removal part will suit your needs
Old Jan 16, 2023 | 02:41 PM
88n94's Avatar
88n94
When you remove the lines from the steering box, if you let them drain out you will be getting most of the fluid out of the system. You could probably get a little more out, sort of flush it, just by adding some new fluid to the system in the normal manner and letting it drain out of those same steering box lines.
Another confirmation here for Type F ATF, it is what is called for in the owners manual. I, personally will accept no substitutes.
KC8QVO
Jun 24, 2019 12:15 PM
wicat3
15
Sep 24, 2012 06:20 PM
DBKER31
1997 - 2003 F150
Oct 21, 2007 09:41 PM
tndiesel
Jul 11, 2007 02:17 PM
Bob Crain
May 19, 2005 04:59 PM
