Need headlight help
Old Jan 14, 2023 | 03:40 PM
tannerhurd's Avatar
tannerhurd
6th Gear
Need headlight help
Need help getting my headlights to work
I believe my cab has been swapped as I have an 88f350
I have no headlights or taillights my other lights are working I’ve tried replacing the headlight switch and the wiring harness that goes into the switch with no luck. I don’t have the high low switch in the floor on my truck any help or ideas would be greatly appreciated
Old Jan 14, 2023 | 10:14 PM
Prototypemech's Avatar
Prototypemech
You'll need to go on eBay and get the EVTM (electrical and vacuum troubleshooting manual) for your gear truck and a multimeter and start wringing out wires. The manuals are a PDF or CD and they run about $40 for the EVTM plus the general repair manuals in a bundle. The multimeter should cost you about $20. With a good set of crimpers and a few butt splices, you should be able to fix it.
Old Jan 15, 2023 | 07:11 AM
tannerhurd's Avatar
tannerhurd
6th Gear
Thank you will order today and update as needed or when it’s fixed
Old Jan 15, 2023 | 07:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
hopefully the warranty tag is still on the "B" pillar to figure out what year cab and electrical you have.
do you have the dimmer switch on the blinker stalk?
have you looked around the driver side floor under th eparking brake to see if maybe someone removed the dimmer switch and never returned it?
if it is a 91 and older cab there should be a 3 wire plug down there, and 2 small screw holes in the floor.
if the dimmer switch is removed, the headlights will not work.
Old Jan 15, 2023 | 08:36 AM
tannerhurd's Avatar
tannerhurd
6th Gear
Update
Found this unplugged or unhooked coming down from the wiring harness attached to the headlight switch but I have zero idea where it would plug in I don’t see an obvious connection spot for it
Old Jan 15, 2023 | 08:53 AM
tjc transport
i ain't rite
that is the plug for the dimmer switch.
with headlights on, take a test light and find the wire with power. i want to say it is the center one. than with a small jumper wire go from the hot to one of the others and you should have headlights. one is for low beams, one for high beams.
red/yellow stripe should be hot with headlight switch pulled out.
red/black stripe should be low beams.
lite green/black stripe should be high beams.
Old Jan 15, 2023 | 09:09 AM
tannerhurd's Avatar
tannerhurd
6th Gear
Very new to anything mechanical so I don’t know how to make a jumper wire, if I just buy the switch and hook it up should that fix my issue?
Old Jan 15, 2023 | 10:04 AM
tjc transport
i ain't rite
yea, that will work to. a jumper wire is simply a small piece of wire with the ends stripped a little bit.
you can just as easily do it with two small screwdrivers. turn on headlights, stick the screwdriver ends in the plug so they make contact with the metal tab in the plug, than touch the two screwdriver metal shafts together. your helper will then tell you the headlights came on. if doing it this way though, make sure the metal parts do not touch anything on the truck.
Old Jan 15, 2023 | 10:37 AM
tannerhurd's Avatar
tannerhurd
6th Gear
so I jumped the wire and got the lights to work so I’m going to go by the switch but I don’t see the plug like connectors that will go into it to make it work I’ll attach a picture of what I’m talking about also I cleaned the connections that are dirty in the picture
Got the lights to work by putting both ends of some pliers on each side (both left side connections together and both ride side together) then cleaned these connections. Going to buy a dimmer switch but I don’t see the connections for the plug on the dimmer switch (little metal ends that look kind of like your standard house wall plug)
Old Jan 15, 2023 | 11:16 AM
tjc transport
i ain't rite
looks like the switch separated is still partly in the plug.
this is the switch:
and the plug:
Old Jan 15, 2023 | 11:21 AM
tjc transport
i ain't rite
you most likely need to stick a flat blade screwdriver between the plug and switch part and pry then apart.
or just buy both and eliminate what you have there, as the contacts in the current plug very well may break when trying too separate it.
Old Jan 17, 2023 | 05:09 PM
tannerhurd's Avatar
tannerhurd
6th Gear
Update
Got the new headlight switch in and it’s working but when the switch is plugged in the headlights won’t turn off, they stay on regardless of the headlight switch being pulled even stay on with the truck turned off, only way to turn off the headlights is to unplug the truck, any ideas how I can fix this?
Old Jan 17, 2023 | 05:28 PM
tjc transport
i ain't rite
probably why they pulled the dimmer switch.
something is not kosher with the headlight switch
it almost sounds like a few wires are shorted out and bypassing the headlight switch
fishbeard
1978 - 1996 Big Bronco
Jan 30, 2017 07:40 PM
1979Ford33
Aug 19, 2014 06:38 PM
mthorlakson
2004 - 2008 F150
Mar 22, 2013 02:43 PM
jasper
Jan 27, 2001 07:57 PM
