Help pinpointing a leak
Old Jan 7, 2023 | 09:52 AM
Elanham59's Avatar
Elanham59
Looking for some insight on where to start, there’s a million resources as to pinpointing a 7.3L oil leak but maybe I’m looking too hard, I’m not seeing it.
I did the EBPV delete because I was leaking from the turbo pedestal but after that job i surprisingly had no leaks!!!! Now, it’s not a major leak but it’s a leak nonetheless, on the front of the oil pan and often times on the starter. The inspection plate is clean, trans is clean, front end of the vehicle from the axle to the bumper is clean. Oil cooler is clean, and my oil filter / drain plug is not loose or stripped. Y’all have any ideas? Is there a line, or part that I’m not thinking of?
Old Jan 7, 2023 | 03:36 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Grab a strong flashlight and spend some time inspecting the valley. Might need to clean up first, grunge can hide sources.
Since the leak is towards the front I'd guess hpop or lpop.
Old Jan 9, 2023 | 07:06 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Clean the valley..... stuff it full of paper towels or something... run it hard down the interstate... then pull out the paper towels looking for oil/diesel spots.... that will help with finding about generally where the leak is.
Old Jan 9, 2023 | 08:40 AM
callforfire's Avatar
callforfire
oil on the starter but the inspection plate is clean? valve cover or oil rail end plug comes to mind.
Hows the exhaust manifold look?
tschwahn
Jun 1, 2022 11:42 AM
Firefighter 1406
Aug 24, 2014 08:02 AM
pushingxthexedge
Feb 16, 2008 06:19 PM
Double AA
Feb 22, 2007 01:14 PM
88f1504x4
Mar 16, 2006 10:19 AM
