Bed Tie Downs
Old Jan 2, 2023 | 10:46 AM
Stumper2's Avatar
Stumper2
Bed Tie Downs
I want to install the bed tie downs that mount on the sides of the bed. I see there is a huge difference in price between genuine Ford and aftermarket. I need both the brackets and cleats. Any experiences / recommendations on aftermarket ones or should I just belly up and get Ford ones?
Old Jan 2, 2023 | 12:02 PM
Poncho450's Avatar
Poncho450
If you get the brackets from Ford, E track accessories will fit into the slots easier and be cheaper than the Ford option.
My experience has been that the Ford cleats or tie downs fit a little too snugly and had to be tapped in or out with a rubber mallet. But others have posted here that they had only a little or no difficulty.
Beast 17's Avatar
Beast 17
Bed tie down
I bought this brand and they have been great for a couple years now. They get used quite often. They are tight to get them installed and required a firm handgrip. I just noticed this set states that they are foldable. The ones I installed were fixed.
Amazon Amazon
Old Jan 2, 2023 | 01:28 PM
minke's Avatar
minke
I've found these satisfactory: https://www.harborfreight.com/e-track-ring-66728.html
More at: https://www.harborfreight.com/search?q=e%20track
Old Jan 2, 2023 | 06:34 PM
Stumper2's Avatar
Stumper2
I’m thinking of going OEM with both brackets and cleats. Any idea if there would be any difference in bracket mounting hole locations between a 2022SD and an earlier truck? I can’t imagine there would be.
Old Jan 3, 2023 | 06:25 AM
Poncho450's Avatar
Poncho450
I think they're the same. I moved the DuraLiner from the bed of a 2020 to a 2022 and the holes I had drilled into the liner matched up to the new truck.
Originally Posted by minke
Those are indeed satisfactory. I've got some from HF and some from Tractor Supply. Faster and easier in my opinion.
Old Jan 3, 2023 | 06:55 AM
Stumper2's Avatar
Stumper2
Well, since the aftermarket ones were the only ones that actually state they fit a 2022 F250, I ordered a set. Will report on fit next week.
Old Jan 3, 2023 | 08:18 AM
Motown Fire's Avatar
Motown Fire
I use the E-Track tie downs listed earlier. They work very well.
CheeseheadFord
Jun 22, 2022 10:03 AM
iwmoose
2009 - 2014 F150
Jun 9, 2018 07:44 AM
mtondreo
1997 - 2003 F150
Aug 20, 2008 05:55 PM
Tsubakihara
1983 - 2012 Ranger & B-Series
Dec 15, 2007 01:42 PM
