Bed tie downs / anchor points
Old Mar 20, 2016 | 12:31 PM
iwmoose's Avatar
iwmoose
I have a 2012 supercrew lariat with a 6.5' bed. I don't really like my factory anchor points in the bed. Any recommendations on a certain brand or style? I have a hard top on the bed now so I'm not interested in any that mount on the rails. They have to be located in the bed. Thanks.
Old Mar 20, 2016 | 07:42 PM
Augster's Avatar
Augster
Since you have the 6.5 bed, I would suggest Ford's own Cargo Management System, which is based on a set of side rails and sliding cleats, load bars, and bed dividers. Your bed is pre-drilled for the rails.
A little on the expensive size, as the rails are $305, cleats $25 each (at least 4 would be ideal), load bars $110 (street prices).
And all compatible with a bed shell.
Old Mar 20, 2016 | 08:58 PM
iwmoose's Avatar
iwmoose
Thanks! I'll look into it. 👍🏼
Old Mar 21, 2016 | 11:36 AM
Turbo Dog's Avatar
Turbo Dog
For a few hundred less $$ you can install some flush mount D rings in the bed floor.
Recessed Pan Fitting - Recessed Tie Down Fittings - Anchor Ring
Old Mar 22, 2016 | 11:55 AM
Olytlr's Avatar
Olytlr
Do you have a canopy/shell/topper or a hard tonneau/cap/whatever people call them? Is a Bedslide an option? Personally, whether I have a canopy or a tonneau that is what I dream about getting. Right now I have a soft tonneau and accessing the bed even though it is folding would be much nicer with a sliding tray. Plus they have tie downs.
Old Jun 7, 2018 | 07:39 AM
Mkeenantruckguy's Avatar
Mkeenantruckguy
Aftermarket tie down anchors
I have a 2016 f150 and i had a similar problem with the factory anchors. Every time i want to ratchet strap something down it was a real pain to hook in to the factory anchors i actually had to bend the hooks to get it in. One of my buddies had these aftermarket anchors that were great, they were bigger and much easier to use and i could use the same bolts to put them on took me ten minutes to swap em out. I got em from www.TuffTiedowns.com
Old Jun 7, 2018 | 10:51 AM
84espy's Avatar
84espy
I used simple eye bolts on the bed lip for my tie downs. They work great, if you are not worried about drilling holes or the look.
Old Jun 9, 2018 | 07:44 AM
rsylvstr's Avatar
rsylvstr
you got me thinking. I have a plastic bed liner and the bed extender.
Going to see about replacing the Torx bolts with some eye bolts and go from there!
T-B_MN
2004 - 2008 F150
Mar 18, 2007 08:08 PM
Deadblow
Jun 13, 2002 09:01 PM
