Oil longevity
Old Jan 1, 2023 | 04:18 PM
RigCity's Avatar
RigCity
Oil longevity
I have a truck with fresh synthetic oil zero miles and 2 hrs of run time over the past year. Should I change the oil? While working on more complex vehicles I have read you should always change the oil after extended down time to “prevent severe engine damage” from the manual. Not sure if that’s the manufacturer being overly cautious or not.
Old Jan 1, 2023 | 04:41 PM
ESwift's Avatar
ESwift
CNCFAB
I would would run it, if it were my truck
Old Jan 1, 2023 | 04:49 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I too would run it without concern as long as there was no contamination of some sort.
Old Jan 1, 2023 | 05:13 PM
RigCity's Avatar
RigCity
She’s about to get fired upppppp!!! Thank You Of course now my ocd is now kicking in but what about the old fuel in the tank….I’m gonna start her up anyways it’s either gonna run or have to get pumped out.
Old Jan 1, 2023 | 05:15 PM
Wes444's Avatar
Wes444
Let it run all the way up to temp. That way any condensation gets worked out. Otherwise run it
Old Jan 1, 2023 | 08:06 PM
RigCity's Avatar
RigCity
Fired up immediately and ran for an hour. She’s midway through a mini overhaul despite only 132k miles. Overdoing it in hopes of only having to perform maintenance going forward. 2.3 is going for the 7.3 longevity!!
Old Jan 2, 2023 | 02:24 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Yeah my take is years make zero impact on oil. All about hours and severity of service.
For long term storage you still need to run engine up to operating temp, including the trans, and run the AC and heater. Operate the front hubs if you have 4WD. Move the seat if you have power seats.
Old Jan 2, 2023 | 09:03 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I bought a 1995 in August that had been sitting for 13 years. It had a tank and a half of fuel in it (2-tank system). After I ran both tanks of fuel throught it (probably almost 200 miles) and filled the tanks with new fuel, I changed the fuel filters and engine oil. There was ZERO difference in the way it ran afterward.
sailorman3
2015 - 2020 F150
Oct 24, 2023 01:52 PM
Wes Hightower
Jul 16, 2018 07:03 PM
soos76
2009 - 2014 F150
40
Mar 27, 2013 06:17 PM
Chuckitall
2009 - 2014 F150
36
Mar 8, 2012 06:58 AM
dgarzoli
May 5, 2005 01:12 PM
