Did I make a mistake?
Old Jan 5, 2023 | 09:34 PM
  #31
351Cleveland C4's Avatar
351Cleveland C4
Originally Posted by Conanski
What fuel pressure do you have and does it hold after the engine is shut off? If you have some leaking injectors that would result in a very rich idle mixture.
It was 32 with the FPR hooked up. I didn't watch the bleed off. Leaking injectors were one of my suspicions.
Old Jan 5, 2023 | 09:37 PM
  #32
Conanski's Avatar
Conanski
Does the AFR go back to somwhat normal values above idle? If so this is a good possibility.
Old Jan 5, 2023 | 09:40 PM
  #33
351Cleveland C4
It gets leaner with RPM. By 2000 rpm it's hitting stoich @ 14.2.
Old Jan 6, 2023 | 11:43 PM
  #34
BigBlue2's Avatar
BigBlue2
Short article from motor trend on thermostats. They say that EFI engines run most efficiently at 195 degrees opening temp and above.
Carburetor vehicles are more efficient at 180 degrees opening temp.
https://www.motortrend.com/how-to/ho...r-classic-car/
Old Jan 7, 2023 | 01:09 AM
  #35
AndyFarms's Avatar
AndyFarms
4wd Low
Good point and pull the vacuum hose off of the fuel pressure regulator and look for fuel entering the vacuum line.
Old Jan 7, 2023 | 02:20 PM
  #36
351Cleveland C4
Fuel pressures hold steady, no bleed off.
Replaced MAP sensor. Saw improvement in idle, but still runs rich.
Old Apr 2, 2023 | 07:43 PM
  #37
351Cleveland C4
Swapped the 180 thermostat back to a 195 after figuring out that fuel maps don't begin to self-tune until the computer sees 185*. (Which it was barely touching with the 180 stat)
It does run better (and leaner) with the 195 thermostat. Operating temp has came back up to 200-205 as it was before the entire engine swap.
I'm still dealing with the falling/surging idle. But I'm hopeful that getting the EEC chipped will correct everything.
JT1991
Feb 26, 2019 09:26 AM
BigJT
Apr 27, 2012 01:53 PM
toyotajeep
21
Mar 3, 2006 10:52 PM
mooktank
Dec 1, 2004 10:02 AM
canabait
Exhaust Systems
Feb 27, 2003 09:31 PM
