Advice Appreciated
What year is the truck? and indicated mileage. odometer only goes to 5 digits, so may
have rolled over 2 - 3 times.
6.9 or 7.3. They both use the same OC. Basically same engine. 7.3 is a bored out 6.9
and went to 1/2" head bolt from the 7/16" and a couple other things.
You bought a used truck, first one was 83 and now 39 yrs old.
Last one built 1994 and is 28 yrs old.
It is all about condition of the body and engine.
Soft brakes could be weak vacuum Pump or Vac leaks.
Maybe a weak Brake Booster.
Rear Drum s need adjusting.
Oil in the Radiator is most likely the Oil Cooler. It is down on the drivers side
under the Exhaust Manifold.
I went through this a few years ago, not the end of the world. Sort of an easy fix,
though a few steps to repair it.
And flush out the engine cooling system.
You didn`t detect coolant in the Oil?
Following link is the Gaskets and "O" Rings kit.
https://www.rockauto.com/en/catalog/...ting+kit,10227
This is what the OC looks like, just posting show you.
https://www.rockauto.com/en/catalog/...il+cooler,2084
Not heating up could be the Thermostat. use the Motorcraft one. Highly recommended
https://www.rockauto.com/en/catalog/...hermostat,2200
https://www.rockauto.com/en/moreinfo...sn=565&jsn=565
Where in the country are you located? and year of truck.
Fill out your signature so people are not asking .
We bought our 86 in 2014, paid $1800, didn`t know if it would make it home the 153 miles.
had to replace 4 tires, Rotors, Calipers and Wheel bearings first thing.
At the time 192K miles.
Today rolled over 322K miles. The engine just keeps on going.
We can walk you through how to fix the things that come up.
Let us know.
Charlie
Best move we ever made.
I made a thread, but thought is was the head gasket blew, 3 guys came back and said OC.
I`ll did it up and post it.
After finally R&Ring the OC, I are and expert now....well sort of. The next time will be
quite a bit quicker. Though I was doing it in January between snow storms.
Found it:
https://www.ford-trucks.com/forums/1...-goodie-3.html
Charlie
HIstorically, soft pedals are cause by air in the brake lines, or maladjusted rear brakes. Ford didn't do a good job of designing the rear brake auto-adjuster, so it's common to have to go under the truck with a screw driver and manually turn the auto-adjuster.
Maybe I should say low to no Vacuum will cause a hard peddle, like pushing on a Brick.
I went through this last spring , I should have remembered that.
I totally agree with with you that the adjusters do not work. (at least on our truck)
They are a pain to adjust from the backing plate, have to hold down the Adjuster
and then turn the Adj. wheel.
I read where a guy removed the drums, adjusted the brakes and put the drum back on.
never heard of doing it that way, but it works. Iam in need of doing it again.
Charlie
At some point I picked up a parts truck with aluminum rims, it came with long acorn style (closed end) chrome lug nuts. The mondo nuts from my '88 won't fit with those rims, and i'm not sure the regular sized open end ones from my '93 would work right as there isn't much clearance at the bottom of the nuts (might be same issue you have) But the long chrome nuts let me use a short socket and keep it up away from the rim and a normal thick impact works fine.
Did you bleed the master cylinder before you installed it? Often times new masters need to be 'bench bled' before/during installation to clear all the air out. Basically you just loop lines from the output back into the reservoir and keep pumping until there are no air bubbles coming out. Then quickly swap out the loop lines for the actual lines and bleed like normal. The ABS thingy on the frame may also need to be bled, or bypassed to fix soft pedal issues on these trucks. The ABS system is rear axle only, and not terribly useful btw...
If you read mt link in post #6, I had to flush the cooling system 6 times with
Cascade Dish Washer soap or Dawn, (may have used both) to get all the oil
out of the cooling system. Then 6 flushes with clear water to make sure the soap
was totally out. I used Distilled water. Then 50/50 Distilled and the precharge
Anti Freeze.
Also replaced all rubber hoses as they were gunky inside.
These engines all have blow by, read it is the larger gap in the rings from what
I have read, and also a engine with a ton of miles.
Some use gap less rings to slow it down when rebuilding an engine.
I guess mine has Blow by, don`t pay any attention to it, but with 338K it`s there.
There will always be something to do on these old trucks from time to time.
Keep on Truckin.
Charlie
Different story back east in the rust belt.
They do use that Brine solution on the roads here in Nevada.
Starting to get that rust bubbles on the right bed arch.
Do grind it out and throw in a bunch of POR back in the hole and
then use POR Patch to fill and sand smooth. But it is growing.
The thing that will put a stop of driving your old truck, is if/when Ca.
won`t let you register your truck. Too old, and or not CARB compliant.
Charlie
