Blown Head Gasket....OH Goodie...
#31
This happens a lot around here. I always check the backseat, under the seat and nearby vehicles. Find a lot of stuff like this. Also have found various odds and ends on the ground because I knew what they were.
#32
It also happens when someone pulls the part, then isn't willing to pay for it. I recall someone wanting the lines, makes a deal for like $50, pulls the IP too... the JY wants $100 or so for it, and can't accept that("Oh, I figured you'd throw in the IP for free").
So, part goes back. I grab it, pay $100(which is a total good deal for an IP+lines) and am happy!
#33
At the PNP`s the IP`s are about $52. Some will then charge about $6 for each hard line.
I got mine with the 40% off, they call it a "Fuel Injection Spider TY" under item# 370-5.
It came to $43.25, and including the timing gear and cover. The mgr was pretty cool, but
I have BS`d with him before.
I went back yesterday and snagged the Injectors, Battery Tray and Coolant bottle from the
83 6.9.
Pulled a bench seat out of a newer F150, seat bottom for driver/pass is contured for your
butt and comes up higher in the back for driver/pass and has a wide arm rest in the middle.
Of course it is porno red.
We`ll take it in and have it reupholstered and replace the POS Seat in the 86.
Was going to do a couple more flushing`s on the engine, but rain/snow today and thru Wed.
Noticed yesterday 3 fuel return caps are leaking on driver side. Dang I had that all dried up.
I have plenty of the 111 "O" Rings thanks to Mc Master-Carr..
I haven`t put the inner fender back on, so replacing the rubber fuel lines that use to go to the long
gone water separator, look pretty easy now. Those are 3/8`s right?
Charlie
83 6.9.
Charlie
#34
Yes the lines are 3/8's. I just got done plugging the pull top for the drain and tapping and adding a ball valve to the bottom for a drain I just have to run the lines.
This way I will have much more water capacity and can still run the 6.9 style fuel filters which are way cheaper even with a wix! And the best part is no leaky fuel heater. Will post pics of the mod one of these days.
Mines never had a water separator so I snagged one out of a junkyard and wanted to fix the problem with them known for sucking air. Interested to see if the sensor works as the plug is still there for it.
#35
Thanks for the fuel line sizes. The filter was long gone when I bought the truck, the 2 hoses are just looped
together. I have wanted to change the old rotted looking things. Looked impossible to get to from the top or
bottom. Now with the inner fender out, I can get down in there.
I have a Racor FL500 filter to install in place of the old one. It is a long one but yes it will fit. I have thought
about installing one and mounting a plate to the two holes on the fender below the hood spring.
I was at PNP a couple months ago and a 85 6.9 had one installed there. So I grabbed the whole thing, plate
and all. It also has a hand primer pump, Soon as I get it taken apart and washed up, I`ll install it.
Here is what a new one looks like. They have 3 filter sizes 2, 10 and 15 micron.
https://www.starmarinedepot.com/racor-500fg-fuel-filter.html?gclid=CjwKCAiAv9riBRANEiwA9Dqv1TSDt-7KAx5U-2BUdER_Hc9ENBez6gMVFRClUvDqouWXl2vJxugu_hoCerIQAvD _BwE
Think I paid about $27 for it. These are a great water trap.
Any one wanting to buy one, be careful, the market is loaded with Chicom knock offs. If you see them listed
for $40 - $75 or what ever, they are junk. E-Bay is loaded with them.
Charlie
Charlie
DouginTahoe
04-05-2005 07:52 PM
