Oil & Lubrication
How hot??
Old May 15, 2002 | 06:31 PM
Flash's Avatar
Flash
How hot??
Old Jul 3, 2002 | 11:17 PM
comertrucks's Avatar
comertrucks
How hot??
Hey guys, I was trying to find out how hot the power steering fluid in my truck gets? I have a 70 F-250 4x4 and was thinking of hooking the return line off the pump into my auto transmission fluid coolerin the radiator since I have a 4spd. Will it work? My truck usually runs at 180 degees but has got up to 200+ a time or two. The radiator is brand new. Thanks for the help.
Old Jul 4, 2002 | 03:14 PM
red ranger's Avatar
red ranger
How hot??
i wouldnt change a thing on the pump...it should be just fine the way it was built...but if you like to change things let us know how you made out good luck
Old Jul 4, 2002 | 03:29 PM
GammaDriver's Avatar
GammaDriver
How hot??
I don't know how hot it gets, but remember you'll be reducing the efficiency of the radiator to cool your engine if you add an additional heat source.
I had a Mazda MX-6 GT Turbo that had a power steering fluid cooler (separate from the radiator), so apparently the stuff could stand being cooled. Personally I feel the biggest issue is filtering the power steering fluid. There are aftermarket power steering fluid filters that can be clamped between a cut line.
Old Jul 6, 2002 | 09:52 PM
4x4x4x4's Avatar
4x4x4x4
How hot??
200 degrees isn't hot enough to worry about.
Old Jul 10, 2002 | 09:24 AM
AOGDEN's Avatar
AOGDEN
How hot??
I had a 1973 & a 1974 Torino wagon, both of them had power steering coolers that mounted just above the pump. Maybe you could find one in a scrap yard and adapt it.
Old Jul 10, 2002 | 10:06 AM
jim henderson's Avatar
jim henderson
How hot??
The Taurus SHO from the lat 80s early 90s had power steering coolers. They were little radiators like things about the size of two packs of cigs taped together. They sat somewhere in the airstream in front of the radiator. A lot of the Chevy cop cars also had the cooler. You might check the yards for one of these models. Shouldn't be hard to adapt.
I think on cop cars it is assumed the engine will be running frequently thus generating heat in the fluid with no air flow and the cops often drive more aggressively than the usual blue hair so the steering may get more of a workout.
I would guess that unless you do a lot of idling or stop and go in hot weather, you probably won't have any problems with heat in the fluid. I have heard however, that changing the fluid periodically is very worthwhile to do.
Good Luck,
Jim Henderson
