ICP problems
Old Dec 26, 2022 | 05:03 PM
Steve237's Avatar
Steve237
4th Gear
ICP problems
I’ve had to replace multiple ICP sensors and pigtails. And still getting the same code p2285,rough idle abrupt turning off and chattering.
i’ve ran the wire and made sure there was no damage in any of the harnesses. But I have read that if I unplug the map sensor it will go off of default data ?
I unplugged the map sensor and the truck ran fine, then plugged it back in and it did the same thing p2285 and also p0237 for the map sensor. I cleared the codes and unplugged the map sensor again and truck ran fine.
Has my map sensor gone bad and that’s why I keep getting p2285 and can’t drive the truck or idle it ?
Old Dec 26, 2022 | 05:07 PM
bismic's Avatar
bismic
What engine do you have in it?
Where are you getting the sensors from?
Old Dec 26, 2022 | 05:43 PM
Steve237's Avatar
Steve237
4th Gear
6.0L 2003. And I’m putting in the ford dealership parts department sensors.
Old Dec 26, 2022 | 06:34 PM
bismic's Avatar
bismic
I asked because your first post was in the 7.3L forum and an 03 can be either.
Can you explain what you mean by "you ran the wire?
Do you have a way to read your v-reference voltage (I assume you do since you are reading the codes)?
Old Dec 26, 2022 | 06:38 PM
Steve237's Avatar
Steve237
4th Gear
I made a mistake with the first post and made the second one sorry about the confusion. But I don’t I have just a generic reader with no live data at the moment.
Old Dec 26, 2022 | 06:46 PM
bismic's Avatar
bismic
That is going to make troubleshooting very hard.
That said, you can check the v-reference voltage (key on) with a DVOM
The MAP and ICP v-reference are from the same PCM supply.
The MAP and ICP signal return are on the same PCM ground.
You may have a bad MAP sensor and it could be corrupting the v-reference circuit or affecting the signal return (PCM ground). I suppose it could also be the MAP connector. Inspect that connector and post up what you see.
Do you have "backprobe pins"?
For the MAP sensor:
The brown wire with white stripe is the v-reference supply voltage (circuit 351) - connects to PCM plug C1381a, pin 45
The gray wire with red stripe is the common signal return (ground) (circuit 359) - connects to PCM plug C1381a, pin 33
The light green wire with the black stripe (middle wire) is the signal wire
C1381a is the left plug.
Gwilkrrs
Aug 26, 2022 10:19 AM
rickdavis81
May 12, 2016 04:34 PM
vintagequest
Jan 20, 2016 05:02 AM
Fanboy
Feb 13, 2008 08:55 AM
