Play in Front Wheel Source
Old Dec 24, 2022 | 11:11 AM
TNT's Avatar
TNT
I replace both front hub bearing assemblies a few years ago. I replaced brake pads last week and now hear a slight rubbing sound that correlates with the wheel spinning. Doesn't change with braking though sounds like a slight rub. Then I noticed the wheel has very slight play in it. Hard to believe the bearing is already worn. Is there anything you can think of that might allow for some play? I don't think there is anything to tighten other than the hub assembly. I'll keep driving it and see if the play gets worse. Could be there has been slight play (I'd say 1/32 ish) since whenever.
Old Dec 24, 2022 | 11:08 PM
Kintla's Avatar
Kintla
Not sure how 1/32 play can be felt. When mine went bad it was pretty obvious. If you think the hub assembly is bad I'd put an automotive stethoscope on the shock while spinning the wheel and listen for growling.
Did you do anything to the calipers or rotors or just change pads? My guess would be run out in rotor or sticking caliper.
Old Dec 25, 2022 | 12:35 AM
TNT's Avatar
TNT
I only changed the pads. New caliper 4-5 years ago. New bearing hub assembly 3 years ago. Very slight movement but can be felt as opposed to right side which has zero play. Hmmm...
Old Dec 25, 2022 | 05:35 AM
udsuth78's Avatar
udsuth78
How are you checking for and noticing this play? When you replaced the pads did you inspect and grease the slide pins? When you replaced the hubs did you verify the build date? If your build date is anywhere close to the cutoff I would pay close attention to what parts come off and go back on. How about the axle pilot bearing in the backside of the hub, they are prone to getting dry and causing issues.
Old Dec 25, 2022 | 10:21 AM
TNT's Avatar
TNT
Good questions. I noticed the play after driving the truck after replacing the pads. I could hear a rubbing sound coming from the wheel that correlated with the speed of the truck so I figured it was related to the wheel/brake/hub. I jacked up the truck to turn the wheel but could not duplicate the sound from either wheel. That's when I noticed there was slight play in the driver's side wheel. I replaced the whole hub assembly three years ago. Can't imagine bearing going bad unless I did something wrong putting it together. I can always replace the hub assembly again (ugh).
Old Dec 26, 2022 | 02:45 PM
FordTruckNoob's Avatar
FordTruckNoob
What size tires are you running? I used to have unit bearings go bad annually.
Old Dec 26, 2022 | 03:10 PM
udsuth78's Avatar
udsuth78
Are you sure the play is in the hub and not ball joints or tie rods? I actually had the bolt hole for the tie rods in both knuckles get egged allowing the frontend to wander. Took a little bit to figure that one out. It's just not a real common failure point in my experience so unless you're looking for it you might not catch it.
Old Dec 27, 2022 | 12:01 PM
TNT's Avatar
TNT
Running BFG All Terrain...recommended size 235. I've heard same thing though on over sized tires. Thanks.
Old Dec 27, 2022 | 12:04 PM
TNT's Avatar
TNT
Possible but I had my son rock tire while I looked at componants and didn't see/feel any movement. But I haven't done the ball joint test. I did have them replaced some years back. I'll double check. Thanks.
Old Dec 27, 2022 | 05:10 PM
FordTruckNoob
If the brakes are binding because of play in the wheel it won’t be ball joints because the brake caliper is bolted to the knuckle. Wheel and brakes will move together as a unit when ball joints go out because it is the entire knuckle moving. Still good to check the health of the ball joints though.
Old Dec 27, 2022 | 05:44 PM
Old and soft's Avatar
Old and soft
Dynatrac. Buy once, cry once
Old Dec 27, 2022 | 06:09 PM
FordTruckNoob
Totally agree but I haven't found a buyer for my liver yet.
Old Dec 27, 2022 | 07:36 PM
udsuth78's Avatar
udsuth78
That's a whole bunch of crying, plus it's not like you never have to worry about hub bearings again. Just a little less hassle when you do.
hambass
May 9, 2017 07:28 PM
handyandy123
Nov 10, 2016 08:50 AM
Tron75
Jul 15, 2013 06:42 PM
Tron75
Jul 14, 2013 12:16 PM
cnelso48
Feb 4, 2010 05:37 PM
