Wiring Hookup for AC Compressor
Old Dec 23, 2022 | 01:29 PM
jbronkema's Avatar
jbronkema
6th Gear
Good afternoon y'all,
I have a '76 F-350 with a 390 engine. I am working on figuring out the wiring in the engine bay and discovered that I had my oil pressure sensor wire plugged into the wire coming from the AC Compressor/AC clutch. However, now I have absolutely no idea what the wire coming from the AC Compressor is supposed to plug into. Any help or guidance would be much appreciated. I have been searching online and looking through wiring diagrams for days now and have found little to nothing.
Old Dec 23, 2022 | 01:47 PM
440 sixpack's Avatar
440 sixpack
You should have a wire in your engine harness for it. can't remember if it's green or brown.
If you find it turn the A/C on and it should be hot.
Old Dec 23, 2022 | 02:01 PM
jbronkema's Avatar
jbronkema
6th Gear
Does that mean that it comes directly from where I turn my AC on? Or would it originate from somewhere else?
Old Dec 23, 2022 | 02:23 PM
Citymorg's Avatar
Citymorg
I don't know if this helps, but I just installed an aftermarket system. There was one wire that went from the condenser to the heat exchanger, and from the heat exchanger to the controls inside the truck. There was only this one wire coming out the condenser.
Old Dec 23, 2022 | 03:36 PM
tbear853's Avatar
tbear853
On my '77 the compressor clutch wire is black and leads back eventually to the "de-icing" switch inside the housing, it has a connecter in the housing, and there's one out there under the hood near the compressor. I did add a under dash mounted "toggle switch with light - leg" in between the two connecters so that I can flip the compressor on while in defrost mode for faster defrost, was surprised long ago that the system didn't do it automaticaly but it doesn't. OEM just blows heated air on the windshield.
Old Dec 23, 2022 | 03:41 PM
440 sixpack
I take it you're looking for the wire to plug into your compressor ? if so it'll be in the harness that goes down the top of the engine. you can just find it and plug it in.
if it's not there then you'll have to find it at the firewall .
Old Dec 23, 2022 | 03:52 PM
tbear853's Avatar
tbear853
It ain't but one wire coming out of the AC housing where the hoses also exit, it might be tied or taped in some wire group on OP's truck.
Old Dec 24, 2022 | 11:18 AM
aldridgec's Avatar
aldridgec
You must mean from compressor to evaporator to controls? The condenser is in front of the radiator and the "heat exchanger" inside is the evaporator. There shouldn't be a wire from in front of the radiator.
Originally Posted by tbear853
so that I can flip the compressor on while in defrost mode for faster defrost, was surprised long ago that the system didn't do it automatically but it doesn't. OEM just blows heated air on the windshield.
I was surprised too. I was actually able to modify the controls so it engages in defrost mode. I had to grind back the ramp that moves the microswitch.
slackadjuster
Feb 24, 2020 09:42 PM
slackadjuster
Feb 21, 2020 11:28 PM
James Howard
May 27, 2014 04:42 PM
svp_evo
Feb 11, 2014 10:35 PM
