brake bleeding problems
Old Nov 13, 2003 | 06:25 PM
79 250 lariat 4x4's Avatar
79 250 lariat 4x4
Got all my new lines in rebuilt the back brakes, bled the back brakes no problem but the fronts won't bleed.. is the proportioning valve closed? any info would be nice
Old Nov 13, 2003 | 07:52 PM
LxMan1's Avatar
LxMan1
It sounds like it might be stuck to the rear brake position. It would probably be easiest to replace it.
Jimmy
Old Nov 13, 2003 | 09:21 PM
79 250 lariat 4x4
cool thanks for the reply.. i was startin to wonder if it was my calipers.. is that possible?
Old Nov 13, 2003 | 09:37 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Someone on the board here mentioned to properly bleed the front brakes there is a pin on the prop valve that needs to be pulled out while bleeding...
Old Nov 13, 2003 | 09:47 PM
tack338's Avatar
tack338
There is a small bleed pin on the proportioning valve, but most get the same results without pulling on it. Some feel it was mostly an assembly aid at the factory. I had the bleed screw tip plug up with crud, so maybe pull it all the way out and see if its plugged, if it is then go buy some new ones for a few bucks if that is the problem. GOOD LUCK
Old Nov 13, 2003 | 11:17 PM
79 250 lariat 4x4
I already removed the bleeders and cleaned them all to make sure they weren't full of crud. how much is a new proportioning valve worth? will i be able to find one at the local parts store
DLGries
1983 - 2012 Ranger & B-Series
Mar 22, 2024 08:02 PM
wrd0225
Aug 3, 2010 10:01 PM
john smith jr
Aug 29, 2008 06:56 AM
iapexl8r
Jul 22, 2006 03:43 PM
bartok
May 2, 2004 09:39 PM
