replacing rear frame
Old Dec 21, 2022 | 11:23 AM
symonds86's Avatar
symonds86
I am going to shrorten my long bed to s short bed next winter and i got to thinking since I put irs in my truck and plan to got with an aftermarket cell with better baffling it might make sense for me to just buy some rectangle tube and build the back half of the frame. I could make it what ever width the front is after the cut and build bed mounts to use existing bed holes. Also make mounts to bolt irs in and also bumper mounts. anyone don this type of thing
Old Dec 21, 2022 | 11:31 AM
redroad's Avatar
redroad
If it's a 2wd, no problem. If it's 4wd then pinion angles and what you have to spend on the project will dictate what you ultimately end up with.
Old Dec 21, 2022 | 04:10 PM
flowney's Avatar
flowney
I believe that this is called "back halfing" which not only offers wheelbase shortening but also offers radical lowering opportunities. That lowering can also involve making the bed shallower in whole or in part. There are a good number of radical custom truck builds that have gone down this path and some are detailed in build threads that can be discovered with a little digging. There are pro shops out there that provide photo essays of such work as a way of soliciting business.
Old Dec 21, 2022 | 07:21 PM
symonds86's Avatar
symonds86
you are correct with the back half term knowing the correct verbiage made it a lot easier to look up. I don’t plan to lower it any more then it is now but I have a weld in c notch from when I had it lowered on leaf spring and have it box here and there from the subframe install and I think think this will be a good way to clean it all up back there and start fresh. Plus the rear irs sub dram would fit better if the frame was just a little narrower so I could do that wen I go shortbox because the frame tapers after the cab where you cut it anyway
Old Dec 22, 2022 | 07:50 PM
73FOMO's Avatar
73FOMO
I shortened mine and added a Boyd’s 23 gallon fuel cell. Check my thread out for some pics, etc. Note all 16” is cut in front of the wheels on ‘73-‘79’s. Came out great.
https://www.ford-trucks.com/forums/1...l#post20629729
Old Dec 27, 2022 | 07:46 PM
speedfreak78's Avatar
speedfreak78
After looking over your build thread, I'd say go for it. If you don't want to build full rails, there are companies that sell pre formed, boxed frame sections for building your own rear suspensions. They're usually geared more towards 4 link/ladder bar type suspensions, but they might work in your situation.
Old Dec 28, 2022 | 11:37 AM
flowney's Avatar
flowney
Indeed you can even buy a complete frame and suspension for dent side trucks:
Only $12K here https://roadstershop.com/product/197...#frame-options but there are several other options available for folks with deep pockets.
Old Dec 29, 2022 | 08:36 AM
speedfreak78
The frame rails I'm talking about are like $600 for a pair, that's not exactly deep pocket territory. Once you consider what the tube is gonna cost, plus the actual time and labor to fab it up, it seems like a pretty affordable option.
ctorres
Oct 28, 2017 01:20 AM
kc0stp
Offroad & 4x4
Nov 8, 2012 05:44 AM
650
Aug 7, 2010 12:25 AM
94F250XL
Dec 6, 2009 07:18 PM
BigJake34452
Jan 16, 2009 04:00 PM
