front end eplacementsparts
Old Dec 20, 2022 | 09:00 AM
boybowser's Avatar
boybowser
Well I knew this day was coming, 97 F250HD 4wd 7.3 PS, 180,000 needs ball joints, probably tie rod ends spring bushings replaced at a minimum cushions at the very front should be replaced. While in there suspect I may as well replace the shock absorbers as well, looking for suggestions as to recommended suppliers, usually use Moog but hearing some complaints re quality as of late so also any suggestions to avoid the typical gotchas as well as what else should I go ahead and replace while I am in there, I have owned this truck since new in 1997 and pretty much everything underneath is original so I am not optimistic this will be an one day job.
I do have the service and evtm manuals but I find many times experience trumps the recommended procedures
Any suggestions and words from the more experienced is greatly appreciated.
Old Dec 21, 2022 | 08:58 AM
jas88's Avatar
jas88
I use Moog and have, so far, not had a problem.
Old Dec 21, 2022 | 10:55 PM
Prototypemech's Avatar
Prototypemech
Check eBay and rockauto for OEM/motorcraft components. They're the best. I picked up a full set of shocks recently and they cured 3 other problems.
Old Dec 22, 2022 | 05:09 AM
Exwhyze's Avatar
Exwhyze
I have had good luck with rockauto for finding motorcraft oem stuff, or moog. Tie rod ends etc should be easy, but getting to the ball joints is gonna be a bit of a fight, especially if you've got 4wd. Might as well do the front wheel bearings while you have them out, too, unless theyre new.
akpolaris
Jun 11, 2014 06:20 PM
bass-n-fire
Jan 29, 2013 07:09 AM
F250_JR
Feb 18, 2012 07:12 AM
trpltongue
Apr 13, 2006 08:19 AM
midchy
Aerostar
Mar 15, 2004 08:17 PM
