Front End Overhaul
Old Jan 28, 2013 | 04:27 PM
bass-n-fire's Avatar
bass-n-fire
Front End Overhaul
I'm about to undergo replacing my tie rod ends, ball joints etc. Is there anything else that I will have to ( should) replace while I'm at it?
Old Jan 28, 2013 | 08:20 PM
bluemtn95ford's Avatar
bluemtn95ford
Im not sure about replacing anything MORE than that. I know I just recently replaced ball joints all around as well as my tie rod ends and I've been fine.
I just gotta say your truck looks beast!! Way ta go!
Old Jan 28, 2013 | 11:43 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
If you haven't done your shocks in awhile, you should consider changing those out as well.
Old Jan 29, 2013 | 04:07 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Shock Absorbers
Axle Pivot Bushings
Tie rod Ends/Sleeves
Upper/Lower Balljoints
And if they're getting bad, Camber Alignment Bushings
Old Jan 29, 2013 | 07:09 AM
DIYiT's Avatar
DIYiT
You could always check your wheel bearings and seals; spindle bearings and seals; and axle shaft u-joints since you'll have the knuckles off. You won't necessarily need to replace them, but if they're questionable, now's the time to do it.
GatorBait1996
Jul 30, 2019 08:29 PM
Long Haul
Nov 30, 2014 10:48 AM
jboo4405
1997 - 2003 F150
Aug 15, 2012 08:08 AM
F250_JR
Feb 18, 2012 07:12 AM
trpltongue
Apr 13, 2006 08:19 AM
