noises
Old Dec 20, 2022 | 09:33 AM
1997.7.3.PSD's Avatar
1997.7.3.PSD
Originally Posted by kitz
No add a leaf and it has 2 leaves is this the way it is supposed to be bowing down the rubber bumper is about a inch from hitting
Those look upside down to me.
Old Dec 20, 2022 | 12:26 PM
farmert's Avatar
farmert
Nope these trucks have negative arch springs installed from the factory.
Old Dec 20, 2022 | 08:15 PM
97-psd's Avatar
97-psd
^^ what he said. That looks normal for a 250. I would expect to see 3 leaves if it had an add a leaf installed. It looks like you have the normal factory 2 leaf.
Old Feb 7, 2023 | 11:21 AM
kitz's Avatar
kitz
Well i checked radiator support bushings used a prybar against radiator support to lift and poked a hole thru the rust. Bushings looked shot so i replaced radiator support and bushings and still have the noises there goes 500 bucks but now i can say it is a 99 % rust free truck.( in iowa that is good) I found on another page that it may be my leaf spring bushings so i ended up replacing them and front shackles another 100 bucks but solved the problem. Thanks for the help guys really appreciate it this forum is very helpful
viperrtblck
Feb 8, 2023 08:19 AM
rockinron
1997 - 2003 F150
Apr 28, 2009 09:56 PM
m14dan
Jun 4, 2007 05:14 PM
Heath67
Sep 14, 2006 11:54 PM
