flat tow option
Old Dec 12, 2022 | 12:26 PM
tiredmec's Avatar
tiredmec
Question flat tow option
my vin decoder says equipped with flat tow mode. Not sure what that means. there are no indicators showing this. what does this mean. behind rv or what??
Old Dec 12, 2022 | 05:35 PM
meborder's Avatar
meborder
Yes, flat tow behind an RV.
there is a method to put the transfer case into neutral. It involves putting the transmission into neutral and cycling the transfer case selector between 4-lo and 2-hi a specific number of times in so many seconds.
the exact procedure will be in your owners manual.
Old Dec 13, 2022 | 01:01 PM
gDMJoe's Avatar
gDMJoe
Arrow
meborder... the exact procedure will be in your owners manual.
» Four-wheel-down Towing section.
Old Dec 17, 2022 | 09:05 AM
Dunrollin's Avatar
Dunrollin
I do this with my 2013 very often and it is real easy. Key on but engine off, shift into neutral, turn the 4wd selector switch from left to right 5 times and a message comes up that neutral tow mode is active, turn key to off but not locked or removed and you are ready to go. If you are on a slope be sure to use the parking brake and this procedure only works with 4 wheel drive, not 2.
billybob12648
Sep 7, 2022 01:18 PM
Ian Clarke
Sep 5, 2022 09:41 PM
Lumpschlevot
All Things Towing
16
Jul 14, 2021 12:46 PM
northernsnooker
Oct 25, 2012 07:58 PM
mountaineer27
Aug 4, 2010 07:19 AM
