Custom transmission lines
Old Dec 11, 2022 | 06:59 PM
2002Limited's Avatar
2002Limited
Finally got around to replacing my transmission lines. The one that goes from the rear of the trans up to the cooler fitting went great - just slid it up from rear to front. For the life of me I could not find a way to get the other one through. Are these made with replacement in mind? I'm not doing anything crazy like lift the engine for a trans line. I cut it and fit a high pressure rubber hose for the part that goes right by the engine. I didn't have any hose clamps at the time, so it's just stuck in as far as I could get it and so far so good I guess.
Old Dec 11, 2022 | 09:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They are designed to be easily installed on the assembly line, before the engine and transmission are installed. There is no effort made to make them easy to replace.
Old Dec 12, 2022 | 06:17 PM
manglass's Avatar
manglass
You might want to get some clamps on that as soon as you can. I'm not certain about 4R100's but other automatics can run 200 psi or so in the cooler lines.
Lou Manglass
Tparkin99
Mar 10, 2016 03:30 PM
asa67_stang
Mar 25, 2014 12:36 PM
1low50
Feb 18, 2010 11:15 PM
f-150 hot rod
1997 - 2003 F150
Nov 8, 2009 08:58 AM
projectbad78
Dec 31, 2008 06:18 PM
