C5 cooler line leaking...
Old Mar 9, 2016 | 05:37 PM
Tparkin99's Avatar
Tparkin99
Hi guys, just picked up an old truck as a project and need a little help with a trans leak...
C5 trans, spewing oil from one of the trans cooler lines. The leaky line has about a foot long section of hose spliced in(with hose clamps) right where it runs past the cat shield. It definitely doesn't look "stock" and I can't imagine why you would want a rubber hose near hot exhaust....? I pulled up the pre bent lines on LMC and by looking at the pic, the piece of hose may be normal. In the pic, where the lines step up toward the trans connector, the black sections look like they may be rubber(or flexible).
Does anyone know if there should be a small section of hose or should the lines be hard lines all the way through?
Thanks in advance for the help!
Old Mar 9, 2016 | 06:28 PM
maytag906's Avatar
maytag906
I'm thinking hard line all the way.
Old Mar 9, 2016 | 07:04 PM
Rusty_S's Avatar
Rusty_S
Cooler lines are hard lines all the way from transmission to cooler. Only the newer cars started using crimped rubber lines at some point in the hardline to allow installation and removal.
Old Mar 9, 2016 | 07:47 PM
Tparkin99's Avatar
Tparkin99
Ok, thanks. That was my first instinct. Is bending new lines pretty straight forward? I assume I can get pre flanged straight lines and bend them to fit? 5/16" ?
Old Mar 9, 2016 | 07:59 PM
Rusty_S's Avatar
Rusty_S
You can try to bend them but there is one problem, if you try to bend it the factory routing it will not be long enough. That's what we did on a '82 we put a 5.0 Coyote in, we have a union coupler under the center line of the radiator.
Old Mar 9, 2016 | 11:16 PM
whisler's Avatar
whisler
I replaced the lines on my "84 C6 with preflanged straight lines hand bent to duplicate factory. I think one of the lines does have a union in it.
Old Mar 10, 2016 | 12:31 PM
Rusty_S's Avatar
Rusty_S
Cant say on a 84, but my 82 is a solid hardline from transmission to radiator. Might have changed it afterwards though, found out apparently from airbag it that in 82 there were two different sized ball joints used on a '82 F150. So who knows.
Old Mar 10, 2016 | 03:30 PM
maytag906's Avatar
maytag906
On a 65 Pontiac that I had a few years ago, I had transmission lines made up from hydraulic hose. They were a bit pricy at about $75.00 each, but I was able to route them effortlessly.
asa67_stang
Mar 25, 2014 12:36 PM
Scoop531
Nov 24, 2013 08:28 AM
ChristopherN
Feb 18, 2012 07:58 PM
smashclash
Dec 6, 2010 06:16 PM
f-150 hot rod
1997 - 2003 F150
Nov 8, 2009 08:58 AM
