Transmission code help oppinion
Old Nov 13, 2003 | 02:12 PM
AdiDcn's Avatar
AdiDcn
i pulled out a code today
628 Excessive convertor clutch slipage
what i go from here i have to rebuild the transmission or just replace the cluch between the engine and trans and all that is in there flyweel torque convertor and all that please oppinions anything would help.
Old Nov 13, 2003 | 05:26 PM
mrshorty's Avatar
mrshorty
What year Explorer?
Not an expert on troubleshooting that code, but problems with the torque converter clutch are in three general areas: electrical, hydraulic, or mechanical. Before replacing anything, I'd start with the electrical tests. I'm familiar with the A4LD, so if you have a '91-'94, I can help you with the electrical tests. The electrical is also easiest to test, so I think it's the best place to start. After the electrical checks out, then you need to check the insides of the transmission.
Old Nov 13, 2003 | 06:22 PM
AdiDcn's Avatar
AdiDcn
its a 95XLT V6 4.0 with 4R55E transmission thank u for helping
Old Nov 13, 2003 | 06:40 PM
oldcarbuff's Avatar
oldcarbuff
i agree with mrshorty. i've heard technicians say that an alternator not putting out enough voltage to keep the battery up will cause all kinds of weird things to happen. They will be trying to find something wrong with the transmission when it was entirely something else.
Old Nov 13, 2003 | 07:47 PM
AdiDcn's Avatar
AdiDcn
how do i know if the alternator is not good no more?
i have problem with electric too when i press gas and go faster the electrical gauge dosent stay in the middle gows all the way to high realy high then at idile gows under half and lights are not so powerful no more.....how to explain
when i accelerate my headlights and dashboard is verry bright
at idile the headlights and the dash board is weak not strong light .....
one more thing my Vss vehicle speed sensor keeps bouncing up and down doesnt stay at corect speed lets say i go with 40
it gives me 40 then 45 or 35 or 30 50 geeps going up and down like crazy and is not stable......
Old Nov 14, 2003 | 09:37 AM
mrshorty's Avatar
mrshorty
I wasn't thinking of the alternator as a possible problem, but it sounds like there could be a bigger issue.
1st quick test for an alternator. Put a voltmeter across the battery terminals (engine off) and note the voltage (Should be around 12 V). Start the engine. The voltage across the terminals should increase by a few volts (14-16 V). If the voltage doesn't increase, that indicates a fault in the charging system.
Another alternative is to get a charging system tester that can test it under load and such. Most parts houses have one and will test your charging system for nothing, in the hopes of selling a battery/alternator. They can usually test it out of the vehicle, too, if you pull the alternator and take it in.
Good luck
jodykc
Oct 24, 2012 10:57 PM
JP02XLT
1983 - 2012 Ranger & B-Series
Feb 13, 2009 01:27 PM
Calf_roper_John
Jan 7, 2008 08:00 PM
klatt_89
General Automotive Discussion
15
Jan 10, 2006 05:49 AM
AdiDcn
Oct 4, 2003 07:21 PM
